How can a function gradient() equal a value?
Old   January 11, 2019, 17:36
Default How can a function gradient() equal a value?
Andrew Somorjai
massive_turbulence is on a distinguished road
Hello Foamers,
I was looking through a tutorial page 110ish on changing boundaries, or modifying them for the files inside OpenFOAM-v1806/src/finiteVolume/fields/fvPatchFields/derived/totalTemperature/
and one of the things I came across in the convectiveHeatFluxFvPatchScalarField.C file was this line (113) for the gradient()?
gradient() = h.value() / k.value() * (Tsur.value() - T);
To compile this folder just use sudo bash and then wmake. This was for OpenFOAM 6?
I attached the complete source already compiled. convectiveHeatFlux.zip
massive_turbulence is offline   Reply With Quote
Old   January 21, 2019, 03:53
Cyp
Cyprien
Cyp is on a distinguished road
Actually, the function
gradient()
is the gradient of the function projected on the normal face to the patch : if f is a scalar, grad(f) is a vector then n.grad(f) is a scalar.
Cheers,
Cyp is offline   Reply With Quote
Old   January 28, 2019, 09:35
Andrew Somorjai
gradient()
Cheers,
Thanks! That part I do understand, it's more of a question about what class or C++ file this function is in. I guess it's an overloaded function with the parenthesis operator but I've never seen a function call made like this in C++ so I'm not sure how this is capable?
call, equality operator, function
[Other] refineWallLayer Error Yuby OpenFOAM Meshing & Mesh Conversion 2 November 11, 2021 12:04
Objective function gradient verification: surface vs volume integral formulation Evgeniy SU2 7 February 27, 2018 07:38
[blockMesh] non-orthogonal faces and incorrect orientation? nennbs OpenFOAM Meshing & Mesh Conversion 7 April 17, 2013 06:42
LiencubiclowRemodel nzy102 OpenFOAM Bugs 14 January 10, 2012 09:53
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 07:51
