Modelling hinge joint for Six DOF solver in OpenFOAM |
December 19, 2018, 07:25 |
Suyog
Rep Power: 8 |
Dear all,
I need to perform computation using Six DOF solver in 'OpenFOAM’. There are two 2D rigid solid bodies in quiescent water domain, having hinge joint in between them. Bodies are free to move in the fluid domain; the only constraint is hinge joint between them. When the force has been applied on the terminal of one of the body, I need to compute trajectory of another body. Basic issue is to model a revolute joint. So, I request you to give some suggestion regarding the same. |
December 29, 2018, 15:23 |
Rep Power: 21 |
This is definitely possible. You need to use the rigidBodyDynamics library.
Frequently Asked Questions about Installing OpenFOAM | wyldckat | OpenFOAM Installation | 3 | November 14, 2023 11:58 |
OpenFOAM Foundation Releases OpenFOAM v2.3.0 | opencfd | OpenFOAM Announcements from OpenFOAM Foundation | 3 | December 23, 2014 03:43 |
Can't get data from OpenFoam to external solver using externalCoupled | perry | OpenFOAM Running, Solving & CFD | 4 | May 26, 2014 08:09 |
New OpenFOAM Forum Structure | jola | OpenFOAM | 2 | October 19, 2011 06:55 |
Force can not converge | colopolo | CFX | 13 | October 4, 2011 22:03 |
