December 15, 2018, 17:41 |
Adding a BC from OF V6 to OF 18.06
Matt Houchin
Rep Power: 9 |
Hi Foamers,
We are currently using the CFD Support distribution of OpenFOAM v6 on our production server and would like to use the swirlFanVelocity boundary condition from OF V18.06. Unfortunately we are not in a position to be able to move over to OF V18.06 to be able to use swirlFanVelocity, so we are adding it to the user defined boundaries. We have compiled the swirlFanVelocity as a dynamic library with wmake (with some modifications to the .C file to make it compatible with the CFD Support distribution), however when we try to run a case (simpleFoam, K-e turbulence model) with the swirl boundary condition we get the following fatal error: Code:
--> FOAM FATAL ERROR: Not implemented From function void Foam::jumpCyclicFvPatchField<Type>::updateInterfaceMatrix(Foam::scalarField&, const scalarField&, const scalarField&, Foam::direction, Foam::UPstream::commsTypes) const [with Type = Foam::Vector<double>; Foam::scalarField = Foam::Field<double>; Foam::direction = unsigned char] in file /opt/OpenFOAM/OpenFOAM-dev/src/finiteVolume/lnInclude/jumpCyclicFvPatchField.C at line 141. FOAM aborting Included are the C, H files and the make files (with a .C extension added for the file upload extension requirement) Last edited by HouchinM; December 16, 2018 at 09:06. Reason: Clarified versions |
December 17, 2018, 14:59 |
Possible explanation (and solution)
Rep Power: 7 |
Hello there!
Allright! First post here . Lets see if I can help. I am not too familiar with boundary conditions. What I can say from a quick code diving session is: 1. Documentation is your friend! Your class is inheriting from fixedJumpFvPatchField<vector>. This class however is inheriting from another class: jumpCyclicFvPatchField<vector>. The function leading to the error is inside this class. If I take a look at the 18.06 class documentation (https://www.openfoam.com/documentati...8H_source.html) you can see that the function updateInterfaceMatrix has two different declarations (both are virtual, basically prescribing an interface for usage in boundary conditions derived from this class, exactly like yours). If you search a bit deeper in the .C files (where all the definitions are) you will find the definition for these functions. One of these calls the macro notImplemented. The signature of the error you are getting matches this function. This is the reason you are getting this error. 2. Is it possible to solve? Depending on how comfortable you are with OpenFOAM (and C++, and templates), this can be done in little time ( assuming it was working in v6). Since the versions are slowly diverging, I am not 100% sure if it will work. 3. How? From my point of view, this boundary condition is working well for scalar and vector types (why? because these are the only template specializations of this function which are not leading to the notImplemented macro. How do I know that? Have a look at the bottom of the jumpCyclicFvPatchField<vector> header (for declarations), the definitions of these "partial" specializations are in jumpCyclicFvPatchFields.C). To wrap it up: Try to find out for which type this error is occuring (tensorField, maybe?) then find the implementation in your working OpenFOAM v 6. Add the specialization declaration and definition to your implementation. Wow, this got longer than expected. Hope this helps a little. All the best for your task! RP |
December 17, 2018, 17:42 |
Matt Houchin
Rep Power: 9 |
Thank you for the quick reply raumpolizei!
Based on your advice, I looked at the jumpCyclicFvPatchField header file for the 18.06 distribution and it appears that a vector definition of jumpCyclicFvPatchField<field>::updateInterfaceMatr ix is included in this header file, which is missing from the V6 distribution. I'm assuming the trivial fix is to include the vector definition of updateInterfaceMatrix to the header file for jumpCyclicFvPatchField. Many thanks! |
December 18, 2018, 03:23 |
Rep Power: 7 |
Yep that should solve your problem. However, one point has to be corrected from my previous answer. As you mentioned, since there is no specialization for type vector in v6, the instantiated class leads directly to the notImplemented macro. I should have recognized that your class is allready inheriting from an instantiated class template with type vector. So this + the reason you mentioned is/was causing that error.
Glad I could help. |
December 18, 2018, 10:02 |
Matt Houchin
Rep Power: 9 |
Thanks for the tips, I am now getting some redefinition errors.
I have followed the steps from the OpenFOAM wiki on implementing new boundary conditions. This requires me to copy the dependencies fixedJumpFvPatchField and jumpCyclicFvPatchField, rename the files and name occurrences in my run directory, include the files and new libraries in the Make folder and run wmake libso. Unfortunately, when I compile jumpCyclicFvPatchField I am getting lots of redefinition errors: Code:
wmake libso . wmakeLnInclude: linking include files to ./lnInclude Making dependency list for source file jumpCyclicMHFvPatchField.C x86_64-w64-mingw32-g++ -m64 -std=c++11 -Dcygwin64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -DMSWIN -DLITTLE_ENDIAN -DMSWIN -DLITTLE_ENDIAN -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -O3 -DNoRepository -ftemplate-depth-100 -I/opt/OpenFOAM/OpenFOAM-dev/src/triSurface/lnInclude -I/opt/OpenFOAM/OpenFOAM-dev/src/meshTools/lnInclude -I/opt/OpenFOAM/OpenFOAM-dev/src/finiteVolume/lnInclude -IlnInclude -I. -I/opt/OpenFOAM/OpenFOAM-dev/src/OpenFOAM/lnInclude -I/opt/OpenFOAM/OpenFOAM-dev/src/OSspecific/MSWindows/lnInclude -c jumpCyclicMHFvPatchField.C -o Make/cygwin64mingw-w64DPInt32Opt/jumpCyclicMHFvPatchField.o jumpCyclicMHFvPatchField.C:31:1: error: redefinition of ‘Foam::jumpCyclicMHFvPatchField<Type>::jumpCyclicMHFvPatchField(const Foam::fvPatch&, const Foam::DimensionedField<Type, Foam::volMesh>&)’ Foam::jumpCyclicMHFvPatchField<Type>::jumpCyclicMHFvPatchField ^ In file included from jumpCyclicMHFvPatchField.H:166:0, from jumpCyclicMHFvPatchField.C:26: jumpCyclicMHFvPatchField.C:31:1: note: ‘Foam::jumpCyclicMHFvPatchField<Type>::jumpCyclicMHFvPatchField(const Foam::fvPatch&, const Foam::DimensionedField<Type, Foam::volMesh>&)’ previously declared here Foam::jumpCyclicMHFvPatchField<Type>::jumpCyclicMHFvPatchField ^ jumpCyclicMHFvPatchField.C:42:1: error: redefinition of ‘Foam::jumpCyclicMHFvPatchField<Type>::jumpCyclicMHFvPatchField(const Foam::jumpCyclicMHFvPatchField<Type>&, const Foam::fvPatch&, const Foam::DimensionedField<Type, Foam::volMesh>&, const Foam::fvPatchFieldMapper&)’ Foam::jumpCyclicMHFvPatchField<Type>::jumpCyclicMHFvPatchField ^ In file included from jumpCyclicMHFvPatchField.H:166:0, from jumpCyclicMHFvPatchField.C:26: jumpCyclicMHFvPatchField.C:42:1: note: ‘Foam::jumpCyclicMHFvPatchField<Type>::jumpCyclicMHFvPatchField(const Foam::jumpCyclicMHFvPatchField<Type>&, const Foam::fvPatch&, const Foam::DimensionedField<Type, Foam::volMesh>&, const Foam::fvPatchFieldMapper&)’ previously declared here Foam::jumpCyclicMHFvPatchField<Type>::jumpCyclicMHFvPatchField I tried asking a general C++ question about this on StackOverflow, but they sent me away saying that the template should not be defined in the C file. jumpCyclicMHFvPatchField.C: Code:
#include "jumpCyclicFvPatchField.H" // * * * * * * * * * * * * * * * * Constructors * * * * * * * * * * * * * * // template<class Type> Foam::jumpCyclicFvPatchField<Type>::jumpCyclicFvPatchField ( const fvPatch& p, const DimensionedField<Type, volMesh>& iF ) : cyclicFvPatchField<Type>(p, iF) {} template<class Type> Foam::jumpCyclicFvPatchField<Type>::jumpCyclicFvPatchField ( const jumpCyclicFvPatchField<Type>& ptf, const fvPatch& p, const DimensionedField<Type, volMesh>& iF, const fvPatchFieldMapper& mapper ) : cyclicFvPatchField<Type>(ptf, p, iF, mapper) {} template<class Type> Foam::jumpCyclicFvPatchField<Type>::jumpCyclicFvPatchField ( const fvPatch& p, const DimensionedField<Type, volMesh>& iF, const dictionary& dict ) : cyclicFvPatchField<Type>(p, iF, dict) { // Call this evaluation in derived classes // this->evaluate(Pstream::commsTypes::blocking); } template<class Type> Foam::jumpCyclicFvPatchField<Type>::jumpCyclicFvPatchField ( const jumpCyclicFvPatchField<Type>& ptf ) : cyclicFvPatchField<Type>(ptf) {} template<class Type> Foam::jumpCyclicFvPatchField<Type>::jumpCyclicFvPatchField ( const jumpCyclicFvPatchField<Type>& ptf, const DimensionedField<Type, volMesh>& iF ) : cyclicFvPatchField<Type>(ptf, iF) {} // * * * * * * * * * * * * * * * Member Functions * * * * * * * * * * * * * // template<class Type> Foam::tmp<Foam::Field<Type>> Foam::jumpCyclicFvPatchField<Type>::patchNeighbourField() const { const Field<Type>& iField = this->primitiveField(); const labelUList& nbrFaceCells = this->cyclicPatch().neighbFvPatch().faceCells(); tmp<Field<Type>> tpnf(new Field<Type>(this->size())); Field<Type>& pnf = tpnf.ref(); Field<Type> jf(this->jump()); if (!this->cyclicPatch().owner()) { jf *= -1.0; } if (this->doTransform()) { forAll(*this, facei) { pnf[facei] = transform ( this->forwardT()[0], iField[nbrFaceCells[facei]] ) - jf[facei]; } } else { forAll(*this, facei) { pnf[facei] = iField[nbrFaceCells[facei]] - jf[facei]; } } return tpnf; } template<class Type> void Foam::jumpCyclicFvPatchField<Type>::updateInterfaceMatrix ( scalarField& result, const scalarField& psiInternal, const scalarField& coeffs, const direction cmpt, const Pstream::commsTypes ) const { NotImplemented; } template<class Type> void Foam::jumpCyclicFvPatchField<Type>::updateInterfaceMatrix ( Field<Type>& result, const Field<Type>& psiInternal, const scalarField& coeffs, const Pstream::commsTypes ) const { Field<Type> pnf(this->size()); const labelUList& nbrFaceCells = this->cyclicPatch().neighbFvPatch().faceCells(); // only apply jump to original field if (&psiInternal == &this->primitiveField()) { Field<Type> jf(this->jump()); if (!this->cyclicPatch().owner()) { jf *= -1.0; } forAll(*this, facei) { pnf[facei] = psiInternal[nbrFaceCells[facei]] - jf[facei]; } } else { forAll(*this, facei) { pnf[facei] = psiInternal[nbrFaceCells[facei]]; } } // Transform according to the transformation tensors this->transformCoupleField(pnf); // Multiply the field by coefficients and add into the result const labelUList& faceCells = this->cyclicPatch().faceCells(); forAll(faceCells, elemI) { result[faceCells[elemI]] -= coeffs[elemI]*pnf[elemI]; } } Code:
#ifndef jumpCyclicFvPatchField_H #define jumpCyclicFvPatchField_H #include "cyclicFvPatchField.H" // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // namespace Foam { /*---------------------------------------------------------------------------*\ Class jumpCyclicFvPatchField Declaration \*---------------------------------------------------------------------------*/ template<class Type> class jumpCyclicFvPatchField : public cyclicFvPatchField<Type> { public: //- Runtime type information TypeName("jumpCyclic"); // Constructors //- Construct from patch and internal field jumpCyclicFvPatchField ( const fvPatch&, const DimensionedField<Type, volMesh>& ); //- Construct from patch, internal field and dictionary jumpCyclicFvPatchField ( const fvPatch&, const DimensionedField<Type, volMesh>&, const dictionary& ); //- Construct by mapping given jumpCyclicFvPatchField onto a new patch jumpCyclicFvPatchField ( const jumpCyclicFvPatchField<Type>&, const fvPatch&, const DimensionedField<Type, volMesh>&, const fvPatchFieldMapper& ); //- Construct as copy jumpCyclicFvPatchField ( const jumpCyclicFvPatchField<Type>& ); //- Construct as copy setting internal field reference jumpCyclicFvPatchField ( const jumpCyclicFvPatchField<Type>&, const DimensionedField<Type, volMesh>& ); // Member functions // Access //- Return the interface type virtual const word& interfaceFieldType() const { return cyclicFvPatchField<Type>::type(); } //- Return the "jump" across the patch as a "half" field virtual tmp<Field<Type>> jump() const = 0; // Evaluation functions //- Return neighbour coupled given internal cell data tmp<Field<Type>> patchNeighbourField() const; //- Update result field based on interface functionality virtual void updateInterfaceMatrix ( scalarField& result, const scalarField& psiInternal, const scalarField& coeffs, const direction cmpt, const Pstream::commsTypes commsType ) const; //- Update result field based on interface functionality virtual void updateInterfaceMatrix ( Field<Type>&, const Field<Type>&, const scalarField&, const Pstream::commsTypes commsType ) const; }; //- Update result field based on interface functionality template<> void jumpCyclicFvPatchField<scalar>::updateInterfaceMatrix ( scalarField& result, const scalarField& psiInternal, const scalarField& coeffs, const direction cmpt, const Pstream::commsTypes commsType ) const; // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // } // End namespace Foam // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // #ifdef NoRepository #include "jumpCyclicFvPatchField.C" #endif // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // #endif Many thanks for your help! |
December 18, 2018, 14:29 |
Rep Power: 7 |
Hey,
don't have much time. Here is what I think: yep, it is ok to rename the files. However, you also have to rename the class. Otherwise it is not possible to differ later between your implementation and the standard one. Should be why the compiler is complaining. I also think you should start learning a bit of C++ and object oriented design. This will get you way faster to your goals. I was also in your position 2 years ago. It's tough at the beginning but it's worth it. Good luck! Cheers RP |
How I can introduce my power heat (W) in chtMultiRegionFoam? | aminem | OpenFOAM Pre-Processing | 32 | August 29, 2019 02:23 |
chtMultiRegionSimpleFoam: crash on parallel run | student666 | OpenFOAM Running, Solving & CFD | 3 | April 20, 2017 11:05 |
conjugateHeatFoam + interFoam | farhagim | OpenFOAM Programming & Development | 15 | July 19, 2016 07:55 |
chtMultiRegionSimpleFoam 3D problem | Lucie | OpenFOAM Pre-Processing | 2 | June 21, 2016 05:23 |
chtMultiRegionSimpleFoam | samiam1000 | OpenFOAM Running, Solving & CFD | 39 | March 31, 2016 08:43 |
