Modifying dynamic mesh solver
Old   November 29, 2018, 22:21
Default Modifying dynamic mesh solver
Ishan Anjikar
ianjikar is on a distinguished road
Hi
I would like to modify simplefoam solver to incorporate an equation based mesh motion. Also the mesh motion will occur when it is close to other given mesh. The equation used for mesh motion consists of surface area term.
I would like to know, if there is a way to tell the solver to check cells which are close to or touching other mesh, calculate the surface area of that cell and then implement mesh motion based on below equation.
// movement of surface point of cell in outward direction (Δx) = surface area * constant //
I am a beginner in c++ programming, so please consider that while replying.
Thank you.
ianjikar is offline   Reply With Quote
dynamic mesh, mesh motion
Compressible Dynamic Mesh Solver in Foam-Extend 3.1 matthewshorter OpenFOAM Programming & Development 1 September 20, 2023 00:14
fluent divergence for no reason sufjanst FLUENT 2 March 23, 2016 17:08
Update of the variables after dynamic mesh motion. gtg258f OpenFOAM Programming & Development 9 January 18, 2014 11:08
Dynamic Mesh solver OF_NACA OpenFOAM 0 June 21, 2011 04:03
