Creating a control from fvSolution before the mesh creation
Old   October 5, 2018, 19:28
Default Creating a control from fvSolution before the mesh creation
Martin
msaravia is on a distinguished road
Hi ! I know this question may result trivial, but I could not manage to do it.
I need to read the fvSolution dictionary without using a reference to the mesh. This is why:
I was creating the control as:
const dictionary& vmfControl = mesh.solutionDict().subDict("VMF");
but now I have a multi region mesh; and although I could add a fvSolution file to every region folder and create a control for every region as
const dictionary& vmfControl = mesh[i].solutionDict().subDict("VMF");
I want to use only one fvSolution file for all the regions.
EDIT: I have created a dictionary using Time as a register
IOdictionary vmfControl
    IOobject
        "vmf",
        runTime.system(),
        runTime,
        IOobject::MUST_READ_IF_MODIFIED,
        IOobject::NO_WRITE
Thanks in advance.
msaravia is offline   Reply With Quote
Old   October 8, 2018, 10:53
Tobi's Avatar
Tobias Holzmann
Tobi has a spectacular aura aboutTobi has a spectacular aura aboutTobi has a spectacular aura about
Send a message via ICQ to Tobi Send a message via Skype™ to Tobi
the mesh is not required, but you need other objects (that are stored inside the mesh object). To get an idea, you have to look into the Doxygen source code guide (https://cpp.openfoam.org/v6/classFoam_1_1IOobject.html).
Here you see the different constructors for the IOobject object. So basically, the mesh will deliver the const objectRegistry &registry object.
So what you can do is, first build an objectRegistry object and use it for constructing your IOdictionary; cf. https://cpp.openfoam.org/v6/classFoa...tRegistry.html
Keep foaming,
Tobias Holzmann
Tobi is offline   Reply With Quote
Old   October 8, 2018, 11:59
Martin
Hi Tobi, thanks for your answer. I have used runTime, which is a registry object. Its being a hard work to dig all OF source code...
[snappyHexMesh] Creating very fine, high accuracy mesh with snappyHexMesh JD_Welch OpenFOAM Meshing & Mesh Conversion 10 July 5, 2023 12:50
[blockMesh] Segmentation Fault when creating block mesh topography (blockMesh) jbrydg01 OpenFOAM Meshing & Mesh Conversion 2 May 11, 2017 06:37
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 19:57
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 10:38
[ICEM] Problem making structured mesh on a surface froztbear ANSYS Meshing & Geometry 4 November 10, 2011 09:52
