Compile openfoam solver into standalone executable file
Old   October 5, 2018, 17:44
Default Compile openfoam solver into standalone executable file
Qi Yang
qiyang is on a distinguished road
I am using ErminePro_trial on Ubuntu16.04 to compile the OpenFOAM solver(strangSplitFoam) into a standalone executable, I added "/opt/openfoam5/etc/bashrc internal" in configure file and added "ld_preload=`echo /opt/openfoam5/platforms/linux64GccDPInt32Opt/lib/" .
The whole paragraph is: "ld_preload=`echo /opt/openfoam5/platforms/linux64GccDPInt32Opt/lib/*.so` && ErmineProTrial.x86_64 strangSplitFoam --config=config --ld_preload="$ld_preload" --output=strangSplitFoam-static"
I got strangSplitFoam-static , but when I run it, it shows
"error while loading shared libraries: libfiniteVolume.so: cannot open shared object file: No such file or directory. "
However, libfiniteVolume.so is already in the ld_preload path.
I am asking that could anyone help me with this.
qiyang is offline   Reply With Quote
Old   October 5, 2018, 17:45
Qi Yang
This is needed dynamic library and path of my program: strangSplitFoam
How can I add them into the config file
ldd strangSplitFoam
linux-vdso.so.1 => (0x00007ffc95d26000)
libfiniteVolume.so => /opt/openfoam5/platforms/linux64GccDPInt32Opt/lib/libfiniteVolume.so (0x00007f8bd71f7000)
libfvOptions.so => /opt/openfoam5/platforms/linux64GccDPInt32Opt/lib/libfvOptions.so (0x00007f8bd6de4000)
libmeshTools.so => /opt/openfoam5/platforms/linux64GccDPInt32Opt/lib/libmeshTools.so (0x00007f8bd676b000)
libsampling.so => /opt/openfoam5/platforms/linux64GccDPInt32Opt/lib/libsampling.so (0x00007f8bd6122000)
libturbulenceModels.so => /opt/openfoam5/platforms/linux64GccDPInt32Opt/lib/libturbulenceModels.so (0x00007f8bd5ccc000)
libcompressibleTurbulenceModels.so => /opt/openfoam5/platforms/linux64GccDPInt32Opt/lib/libcompressibleTurbulenceModels.so (0x00007f8bd5802000)
libreactionThermophysicalModels.so => /opt/openfoam5/platforms/linux64GccDPInt32Opt/lib/libreactionThermophysicalModels.so (0x00007f8bd4ee5000)
libspecie.so => /opt/openfoam5/platforms/linux64GccDPInt32Opt/lib/libspecie.so (0x00007f8bd49e7000)
libcompressibleTransportModels.so => /opt/openfoam5/platforms/linux64GccDPInt32Opt/lib/libcompressibleTransportModels.so (0x00007f8bd47e3000)
libfluidThermophysicalModels.so => /opt/openfoam5/platforms/linux64GccDPInt32Opt/lib/libfluidThermophysicalModels.so (0x00007f8bd4299000)
libchemistryModel.so => /opt/openfoam5/platforms/linux64GccDPInt32Opt/lib/libchemistryModel.so (0x00007f8bd37ef000)
libODE.so => /opt/openfoam5/platforms/linux64GccDPInt32Opt/lib/libODE.so (0x00007f8bd35a5000)
libcombustionModels.so => /opt/openfoam5/platforms/linux64GccDPInt32Opt/lib/libcombustionModels.so (0x00007f8bd320d000)
libmixCanteraFoam.so => /root/OpenFOAM/root-5.0/platforms/linux64GccDPInt32Opt/lib/libmixCanteraFoam.so (0x00007f8bd2c36000)
libOpenFOAM.so => /opt/openfoam5/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so (0x00007f8bd20e0000)
libdl.so.2 => /lib/x86_64-linux-gnu/libdl.so.2 (0x00007f8bd1edc000)
libstdc++.so.6 => /usr/lib/x86_64-linux-gnu/libstdc++.so.6 (0x00007f8bd1b5a000)
libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007f8bd1851000)
libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1 (0x00007f8bd163b000)
libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007f8bd1271000)
libPstream.so => /opt/openfoam5/platforms/linux64GccDPInt32Opt/lib/openmpi-system/libPstream.so (0x00007f8bd1061000)
libtriSurface.so => /opt/openfoam5/platforms/linux64GccDPInt32Opt/lib/libtriSurface.so (0x00007f8bd0dc2000)
libsurfMesh.so => /opt/openfoam5/platforms/linux64GccDPInt32Opt/lib/libsurfMesh.so (0x00007f8bd0ab1000)
libfileFormats.so => /opt/openfoam5/platforms/linux64GccDPInt32Opt/lib/libfileFormats.so (0x00007f8bd0826000)
liblagrangian.so => /opt/openfoam5/platforms/linux64GccDPInt32Opt/lib/liblagrangian.so (0x00007f8bd05fc000)
libdynamicMesh.so => /opt/openfoam5/platforms/linux64GccDPInt32Opt/lib/libdynamicMesh.so (0x00007f8bcfe9b000)
libconversion.so => /opt/openfoam5/platforms/linux64GccDPInt32Opt/lib/libconversion.so (0x00007f8bcfc18000)
libsolidThermo.so => /opt/openfoam5/platforms/linux64GccDPInt32Opt/lib/libsolidThermo.so (0x00007f8bcf91d000)
libsolidSpecie.so => /opt/openfoam5/platforms/linux64GccDPInt32Opt/lib/libsolidSpecie.so (0x00007f8bcf6ee000)
libthermophysicalProperties.so => /opt/openfoam5/platforms/linux64GccDPInt32Opt/lib/libthermophysicalProperties.so (0x00007f8bcf3d6000)
libsundials_cvodes.so.2 => /usr/lib/libsundials_cvodes.so.2 (0x00007f8bcf1a3000)
libsundials_nvecserial.so.0 => /usr/lib/libsundials_nvecserial.so.0 (0x00007f8bcef9f000)
liblapack.so.3 => /usr/lib/liblapack.so.3 (0x00007f8bce7a7000)
libblas.so.3 => /usr/lib/libblas.so.3 (0x00007f8bce538000)
libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0 (0x00007f8bce31b000)
libz.so.1 => /lib/x86_64-linux-gnu/libz.so.1 (0x00007f8bce101000)
/lib64/ld-linux-x86-64.so.2 (0x00007f8bd901d000)
libmpi.so.12 => /usr/lib/libmpi.so.12 (0x00007f8bcde2b000)
libextrudeModel.so => /opt/openfoam5/platforms/linux64GccDPInt32Opt/lib/libextrudeModel.so (0x00007f8bcdc0b000)
libgfortran.so.3 => /usr/lib/x86_64-linux-gnu/libgfortran.so.3 (0x00007f8bcd8e0000)
libibverbs.so.1 => /usr/lib/libibverbs.so.1 (0x00007f8bcd6d1000)
libopen-rte.so.12 => /usr/lib/libopen-rte.so.12 (0x00007f8bcd457000)
libopen-pal.so.13 => /usr/lib/libopen-pal.so.13 (0x00007f8bcd1ba000)
libquadmath.so.0 => /usr/lib/x86_64-linux-gnu/libquadmath.so.0 (0x00007f8bccf7b000)
libhwloc.so.5 => /usr/lib/x86_64-linux-gnu/libhwloc.so.5 (0x00007f8bccd41000)
librt.so.1 => /lib/x86_64-linux-gnu/librt.so.1 (0x00007f8bccb39000)
libutil.so.1 => /lib/x86_64-linux-gnu/libutil.so.1 (0x00007f8bcc936000)
libnuma.so.1 => /usr/lib/x86_64-linux-gnu/libnuma.so.1 (0x00007f8bcc72b000)
libltdl.so.7 => /usr/lib/x86_64-linux-gnu/libltdl.so.7 (0x00007f8bcc521000)
Thanks
[swak4Foam] swak4foam for OpenFOAM 4.0 mnikku OpenFOAM Community Contributions 80 May 17, 2022 09:06
wmake compiling new solver mksca OpenFOAM Programming & Development 14 June 22, 2018 07:29
[OpenFOAM.org] Error creating ParaView-4.1.0 OpenFOAM 2.3.0 tlcoons OpenFOAM Installation 13 April 20, 2016 18:34
SparceImage v1.7.x Issue on MAC OS X rcarmi OpenFOAM Installation 4 August 14, 2014 07:42
[swak4Foam] funkySetFields compilation error tayo OpenFOAM Community Contributions 39 December 3, 2012 06:18
