Difference of the max function result with full field, internalField and boundaryFiel
Old   October 2, 2018, 06:00
Default Difference of the max function result with full field, internalField and boundaryFiel
cyss38's Avatar
Cyrille Bonamy
cyss38 is on a distinguished road
I don't understand something about the max function in OpenFoam :
With the following code lines :
Info<< "Full Field Max =" << max(pa).value()<<endl;
Info<< "boundary Field Max =" << max(pa.boundaryField()) <<endl;
Info<< "internal Field Max =" << max(pa.internalField()).value() <<endl;
I have the output :
Full Field Max = 1.45125e+06
boundary Field Max = 2.13539e-08
internal Field Max = 176.63
Can you explain why "internal Field max" and "Full Field max" are different?
PS : It is a parallel computing.
cyss38 is offline   Reply With Quote
Old   October 2, 2018, 06:39
cyss38's Avatar
Cyrille Bonamy
Ok... I have the explanation.
I think there is a problem with max(pa).value in parallel case.
If i use gMax(pa), the result is coherent with the internalFiel result.
boundaryfield, intenalfield, max
