Compiling new liquids libraries in OpenFOAM 6.0 version
Old   September 26, 2018, 16:20
Default Compiling new liquids libraries in OpenFOAM 6.0 version
Luis Fernando Rua Mojica
ruamojica is on a distinguished road
Hi everyone, I'm trying the new version of OpenFOAM, and the creation of new liquid libraries in this seems to be changed and the files structures had some difference to the 4.0 version.
I have the follow error...
wmake libso
wmake libso .
wmakeLnInclude: linking include files to ./lnInclude
Making dependency list for source file C15H32.C
could not open file NSRDSfunc0.H for source file liquidProperties/C15H32/C15H32.C due to No such file or directory
could not open file NSRDSfunc1.H for source file liquidProperties/C15H32/C15H32.C due to No such file or directory
could not open file NSRDSfunc2.H for source file liquidProperties/C15H32/C15H32.C due to No such file or directory
could not open file NSRDSfunc3.H for source file liquidProperties/C15H32/C15H32.C due to No such file or directory
could not open file NSRDSfunc4.H for source file liquidProperties/C15H32/C15H32.C due to No such file or directory
could not open file NSRDSfunc5.H for source file liquidProperties/C15H32/C15H32.C due to No such file or directory
could not open file NSRDSfunc6.H for source file liquidProperties/C15H32/C15H32.C due to No such file or directory
could not open file NSRDSfunc7.H for source file liquidProperties/C15H32/C15H32.C due to No such file or directory
could not open file NSRDSfunc14.H for source file liquidProperties/C15H32/C15H32.C due to No such file or directory
could not open file APIdiffCoefFunc.H for source file liquidProperties/C15H32/C15H32.C due to No such file or directory
Making dependency list for source file liquidProperties.C
g++ -std=c++11 -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=64 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -Wno-attributes -O3 -DNoRepository -ftemplate-depth-100 -I/home/combustion/OpenFOAM/OpenFOAM-6/src/thermophysicalModels/specie/lnInclude -IlnInclude -I. -I/home/combustion/OpenFOAM/OpenFOAM-6/src/OpenFOAM/lnInclude -I/home/combustion/OpenFOAM/OpenFOAM-6/src/OSspecific/POSIX/lnInclude -fPIC -c liquidProperties/liquidProperties/liquidProperties.C -o Make/linux64GccDPInt64Opt/liquidProperties/liquidProperties/liquidProperties.o
g++ -std=c++11 -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=64 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -Wno-attributes -O3 -DNoRepository -ftemplate-depth-100 -I/home/combustion/OpenFOAM/OpenFOAM-6/src/thermophysicalModels/specie/lnInclude -IlnInclude -I. -I/home/combustion/OpenFOAM/OpenFOAM-6/src/OpenFOAM/lnInclude -I/home/combustion/OpenFOAM/OpenFOAM-6/src/OSspecific/POSIX/lnInclude -fPIC -c liquidProperties/C15H32/C15H32.C -o Make/linux64GccDPInt64Opt/liquidProperties/C15H32/C15H32.o
In file included from liquidProperties/C15H32/C15H32.C:26:0:
liquidProperties/C15H32/C15H32.H:39:10: fatal error: NSRDSfunc0.H: No such file or directory
#include "NSRDSfunc0.H"
compilation terminated.
/home/combustion/OpenFOAM/OpenFOAM-6/wmake/rules/General/transform:25: recipe for target 'Make/linux64GccDPInt64Opt/liquidProperties/C15H32/C15H32.o' failed
make: *** [Make/linux64GccDPInt64Opt/liquidProperties/C15H32/C15H32.o] Error 1
I don't know how to link the NSRDS function libraries
Someone has had a similar problem?
ruamojica is offline   Reply With Quote
Old   September 26, 2018, 21:06
fedvasu is on a distinguished road
can you inspect if liquidProperties folder has any of those files?
It seems that folder is supposed to be local in your directory.
And execute this in your compilation directory
tree -d
tree
tree
isn't installed install it.
fedvasu is offline   Reply With Quote
OpenFOAM v3.0.1 Training, London, Houston, Berlin, Jan-Mar 2016 cfd.direct OpenFOAM Announcements from Other Sources 0 January 5, 2016 04:18
OpenFOAM cloud computing on Rescale with custom libraries LukaD OpenFOAM Running, Solving & CFD 5 September 11, 2015 10:38
Openfoam mac: Compiling custom libraries atareen64 OpenFOAM 3 April 14, 2011 12:01
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 wyldckat OpenFOAM Announcements from Other Sources 3 September 8, 2010 07:25
OpenFOAM Version 1.1 Released OpenFOAM discussion board administrator OpenFOAM Announcements from ESI-OpenCFD 0 March 11, 2005 06:33
