September 24, 2018, 06:21 |
Mesh Modification Adjoint
Massachusetts
Rep Power: 11 |
Hello everyone,
What is the procedure you usually follow to modify the geometry after a topological optimization? I need to produce a CAD file of the optimized geometry I calculated to test it. Does any specific utility exist? In general I need to eliminate some cells based on the porosity I found from the adjoint solution. Thank for help |
[snappyHexMesh] Add Mesh Layers doesnt work on the whole surface | Kryo | OpenFOAM Meshing & Mesh Conversion | 13 | February 17, 2022 08:34 |
moveDynamicMesh wrong mesh for terrain modification | be_inspired | OpenFOAM Running, Solving & CFD | 2 | January 29, 2021 17:13 |
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 06:38 |
Shape optimization doesn't converge - Adjoint log file | JPBLourenco | SU2 Shape Design | 0 | December 11, 2017 09:41 |
[Other] Modification of a mesh during runtime | Scofield | OpenFOAM Meshing & Mesh Conversion | 6 | October 15, 2013 13:49 |
