changing the boundary values of a volSymmTensorField
Old   September 20, 2018, 15:10
Default changing the boundary values of a volSymmTensorField
A. Min
alimea is on a distinguished road
Hi all,
I have defined a volSymmTensorField named tau1 and initialized with tau. tau is volSymmTensorField that is IOobject and has initial and boundary values in "0" folder. So the initial and boundary values of tau1 is the same as tau.
Now I want to change the values of the internal and boundary of tau1 like this:
forAll(tau1 , i)
     tau1[i].xy() = 40.5;
the internal values are changed, but the boundary values of tau1 are not changed!
What should I do?
Thanks
alimea is offline   Reply With Quote
boundary, boundary condition, openfoam, volsymmtensorfield
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 07:20
Waterwheel shaped turbine inside a pipe simulation problem mshahed91 CFX 3 January 10, 2015 12:19
Low Mixing time Problem Mavier CFX 5 April 29, 2013 01:00
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 08:00
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 16:55
