Calculation of Gradient of a Tensor (Stress) in Cylindrical Coordinates in openFoam
Old   September 19, 2018, 05:08
Default Calculation of Gradient of a Tensor (Stress) in Cylindrical Coordinates in openFoam
A. Min
alimea is on a distinguished road
Hi all,
I need to calculate
d/dr(tau_rt) , d/dt(tau_tt)
where tau is stress tensor that is a volSymmTensorField and r , t are polar coordinates components.
I have two problem:
1- Foam doesn't have cylindrical coordinates
2- the function "fvc::grad(X)" can't get a volSymmTensorField as input.
Could you please help me if you have any similar experience?
alimea is offline   Reply With Quote
Old   October 27, 2018, 05:01
Emad Tandis
EmadTandis is on a distinguished road
Originally Posted by alimea View Post
Hi all,
I need to calculate
I have two problem:
Hello
I have a same problem. Did you find any method to calculate fvc::grad(tensorField)?
EmadTandis is offline   Reply With Quote
Old   October 27, 2018, 05:22
A. Min
Originally Posted by EmadTandis View Post
Hello
Hi
Unfortunately I didn't find any solution, however I defined some volScalarField for every component of stress tensor separately and then calculated the derivative of them.
Old   October 27, 2018, 09:20
Emad Tandis
Thanks Ali
I did ignore this term in my equation and in this way I solved the problem! But it shouldn't be that difficult to implement this function for tensorFields and I wondered when couldn't find it in OF.
Old   February 7, 2021, 15:48
roozbeh
roozbeh_s is on a distinguished road
Hi
Dear Alimea,
how did you do that. Could you share your procedure. Also, what did you do for boundaries?
roozbeh_s is offline   Reply With Quote
Old   February 7, 2021, 16:11
HPE
HPE's Avatar
Herpes Free Engineer
HPE is on a distinguished road
Maybe these help? (haven't used them):
https://github.com/OpenFOAM/OpenFOAM...ld/cylindrical
https://develop.openfoam.com/Develop...temTransform.H
HPE is offline   Reply With Quote
Old   February 7, 2021, 17:59
roozbeh
Originally Posted by HPE View Post
Thanks so much. I skimmed through those, but they are used for transforming between Cartesian- and Cylindrical-coordinate systems. But I couldn't find the Gradient operator for the tensor field. Actually, my main concern is taking the gradient of volTensorField to solve the following equation:
div(grad(T)&&grad(T)),
and T is a second-order tensor.
cylindrical, gradient, openfoam, stress, volsymmtensorfield
Map of the OpenFOAM Forum - Understanding where to post your questions! wyldckat OpenFOAM 10 September 2, 2021 06:29
OpenFOAM v3.0+ ?? SBusch OpenFOAM 22 December 26, 2016 15:24
OpenFOAM v3.0.1 Training, London, Houston, Berlin, Jan-Mar 2016 cfd.direct OpenFOAM Announcements from Other Sources 0 January 5, 2016 04:18
OpenFOAM Training, London, Chicago, Munich, Sep-Oct 2015 cfd.direct OpenFOAM Announcements from Other Sources 2 August 31, 2015 14:36
SIMPLE algorithm in 3D cylindrical coordinates zouchu Main CFD Forum 1 January 20, 2014 18:02
