issue with gdbOF with eclipse
Old   September 17, 2018, 18:45
Smile issue with gdbOF with eclipse
Chen Shen
Giantsda is on a distinguished road
Hello:
gdbOF is a tool that is attached to GNU gdb.
I can run gdbOF commands in gdb now like pfvMatrixFul which writes matrix to a file.
The problem is:
When I try to debug the program in eclipse, I cannot run any gdbOF command in gdb window.
It says:Undefined command: "pfvMatrixFul". Try "help".
Any clue?
Additional info:
1. If you want to debug Openfoam with eclipse and you are using Ubuntu, you need to download GNU gdb, and over writtern the Ubuntu version gdb (by modify PATH in ~/.bashrc). Or when you try to view the variable values, eclipse will hang, at least in Ubuntu 16.
2. Now, I am using gdb-tui if I want to use gdbOF feature. It works fine.
simply do:
gdb-tui or
gdb, then Ctrl+X+A to enable the TUI mode.
3. If you do not like TUI mode, you can do it in emacs. It works fine too.
DO:
1. emacs &
2. in emacs, do: Alt+x, and type gud-gdb
3. run it with: run -case (path/of/the/case/file)
And you can use all gdbOF features.
4. I just do not know why it does not work with eclipse. I am a lazy guy who wants to just click mouse so I am trying to make it work in eclispe.
Best,
Chen
Giantsda is offline   Reply With Quote
eclipse, emacs, gdbof
[Tutorial] Eclipse for OpenFOAM: "fixing" the indexer floquation OpenFOAM Programming & Development 9 April 13, 2017 11:29
OpenFoam 2.X and Eclipse Kepler x86_64leon OpenFOAM Programming & Development 14 September 6, 2014 20:28
Strange issue while launching ANSYS workbench in CentOS 6.4 Philip_C ANSYS 11 August 29, 2013 07:44
CyclicAMI Issue In OpenFOAM 2.2.0 prasant OpenFOAM Running, Solving & CFD 17 March 16, 2013 03:00
Debugging in Eclipse carowjp OpenFOAM Programming & Development 1 October 1, 2011 17:06
