vectorCodedSource - only the x-component?
Old   September 11, 2018, 11:44
Default vectorCodedSource - only the x-component?
Craig White
DSMC123 is on a distinguished road
I have a working vectorCodedSource:
momentumSource
    type            vectorCodedSource;
    active          on;
	selectionMode   cellSet;
	cellSet        ionicWindRegion;
    vectorCodedSourceCoeffs
		fieldNames (U);
		redirectType    velocitySource;
		codeCorrect
                      Pout<< "**codeCorrect**" << endl;
               codeAddSup
                      Pout << "***codeAddSup***" << endl;
               codeSetValue
                        Pout<< "**codeSetValue**" << endl;
			cellSet selectedCells(mesh_, cellSetName_);
			labelList cells = selectedCells.toc();
			vectorField values(cells.size());
			forAll(cells, i)
				scalar ccX = mesh_.cellCentres()[cells[i]].x()*1000.0;
				scalar ccY = mesh_.cellCentres()[cells[i]].y()*1000.0;
				scalar Umax = someEquation;
				scalar Unorm = someOtherEquation;
				scalar Ux = Umax*Unorm;
				values[i] = Ux;
				values[i].y() = 0.0;
				values[i].z() = 0.0;
			eqn.setValues(cells, values);
        // Dummy entry. Make dependent on above to trigger recompilation
        code
            $codeInclude
            $codeCorrect
            $codeAddSup
            $codeSetValue
//     sourceTimeCoeffs
    velocitySourceCoeffs
    // Dummy entry
This works as expected, but ideally I would only constrain the x-component of velocity, I get a nonphysical looking velocity field because it keeps setting the y-component to zero inside the cellSet. Is it possible to only constrain one component of the velocity? If I don't set all 3 components, I of course get runtime errors.
Thanks!
DSMC123 is offline   Reply With Quote
Error message: Insufficient Catalogue Size Paresh Jain CFX 33 August 16, 2024 06:09
Error running openfoam in parallel fede32 OpenFOAM Programming & Development 5 October 4, 2018 17:38
Multiphase flow - incorrect velocity on inlet Mike_Tom CFX 6 September 29, 2016 02:27
Momentum source coefficient, cylindrical coordinates, circumferential component? polakse CFX 15 January 18, 2016 03:40
UDF component in Cyliderical Velocity? Hongchan Kim FLUENT 3 April 24, 2001 13:20
