Scotch 6.0 with OpenFOAM 2.1.1
Old   September 10, 2018, 10:46
Default Scotch 6.0 with OpenFOAM 2.1.1
Pete
strakey is on a distinguished road
Hi All - I have been trying to get scotch-6.0.0 (from ThirdParty-2.3.0) to work with OpenFOAM-2.1.1 due to dgraphFoldComm errors with scotch-5.1.11. I am using a custom solver that incorporates dynamic load balancing with ptscotch. I copied the scotch-6.0.0 folder into the ThirdParty-2.1.1 folder, changed the scotch.sh file to point to the new scotch folder and recompiled. Everything seems to compile OK, but when I run my solver I get a warning about "undefined symbol: SCOTCHorderSaveTree" which prevents my load balancing library from loading.
Has anybody seen this warning/error before or figured out a work around for the dgraphFoldComm errors?
Thanks
Pete
strakey is offline   Reply With Quote
Old   September 14, 2018, 13:03
Domenico Lahaye
dlahaye is on a distinguished road
you probably need to extend the definition of the environment variable LD_LIBRARY_PATH to include the path to where Scotch stores its library files.
To see the current definition of LD_LIBRARY_PATH, do
echo $LD_LIBRARY_PATH
To extend its definition, do
export LD_LIBRARY = $LD_LIBRARY_PATH:<PATH_TO_SCOTCH_LIBRARY_PATH>
dlahaye is offline   Reply With Quote
Old   September 17, 2018, 14:38
Pete
Thanks dlahaye. I finally figured it out today. I had to compile my mesh balancing library with -lscotchDecomp as well as -lptscotchDecomp in the LIB_LIBS=... Apparently my library needed both of these with scotch 6 whereas it only needed the ptscotch library with scotch 5.
Pete
dgraph fold comm, ptscotch, scotch order save tree
[OpenFOAM.org] Install OpenFOAM 2.4.x using system Scotch cbcoutinho OpenFOAM Installation 7 October 16, 2019 20:12
OpenFOAM Training, London, Chicago, Munich, Houston 2016-2017 cfd.direct OpenFOAM Announcements from Other Sources 0 September 14, 2016 04:19
OpenFOAM Training, London, Chicago, Munich, Sep-Oct 2015 cfd.direct OpenFOAM Announcements from Other Sources 2 August 31, 2015 14:36
conjugateHeatFoam with OpenFOAM 2.1.1 rou OpenFOAM Programming & Development 4 April 24, 2015 06:23
Install/compile fireFoam 1.6-1.0 in Openfoam 2.1.1 hz283 OpenFOAM Programming & Development 19 April 1, 2013 09:35
