mapToSurface in surfactantFoam OF1712
Old   August 29, 2018, 10:58
Default mapToSurface in surfactantFoam OF1712
ano
ano
ano is on a distinguished road
I would like to map the boundaryField of the volScalarField Cvf to the areaScalarField Cs, to use afterwards fac:: operators on the boundary data.
I got a "template argument deduction/substitution failed" when I used:
Cs.primitiveFieldRef()=vsm.mapToSurface(Cvf.boundaryFieldRef());
It works with
Cs.primitiveFieldRef()=vsm.mapToSurface<scalar>(Cvf.boundaryFieldRef());
1. Is it possible to use mapToSurface without explicit declaration of the Type? It works for foam extend, but not for OF1712.
2. And would it make sense to overload the = operator for areaScalarField, so that one has not to use the primitiveFieldRef()? It looks not very OpenFoamish at the moment, but perhaps there is a good reason to not overload it.
3. Since no solver is using mapToSurface (the others are only using mapToVolume), is there a better method to transfer the boundaryField data from volField to areaField?
ano is offline   Reply With Quote
[waves2Foam] surfaceElevation not found under OF1712 blaise OpenFOAM Community Contributions 20 December 15, 2020 13:50
SurfactantFoam visualization of areaScalarField jaswi OpenFOAM Running, Solving & CFD 4 October 25, 2018 10:31
finiteArea mapToSurface Andrew.Coughtrie OpenFOAM Programming & Development 4 March 6, 2018 05:31
Problems with cyclic boundaries in faMeshDefinition and surfactantFoam safre OpenFOAM 3 December 12, 2011 08:56
Errors with surfactantFoam While Compiling OpenFOAM141dev from extends chegdan OpenFOAM Installation 1 July 3, 2008 22:10
