August 28, 2018, 11:23 |
assign symmetry for 1D model
Wenming Yang
Rep Power: 8 |
Dear all,
I am developming a solver using the LaplacianFoam. The problem to be solved is in a region with central symmetry, so one dimensional modelling should be OK. But the results in 1D case is not correct, while for 3D one is correct. I do not know how to assign the central symmetry for a 1D model. Thank you. |
1 dimension, central symmetry, model |
[Workbench] Applied a Symmetry function in Design Modeler. Results for the whole model? | Alicja | ANSYS Meshing & Geometry | 0 | October 4, 2016 15:50 |
Superlinear speedup in OpenFOAM 13 | msrinath80 | OpenFOAM Running, Solving & CFD | 18 | March 3, 2015 05:36 |
K - epsilon VS SST turbulence model | Maicol | Main CFD Forum | 0 | November 30, 2012 16:25 |
[ICEM] Blocking and Symmetry | BrolY | ANSYS Meshing & Geometry | 32 | August 24, 2012 03:13 |
Symmetry model half or total geometrical model in LES | vvqf | OpenFOAM Pre-Processing | 3 | March 22, 2006 09:06 |
