Computing the flux at an arbitrary 2D surface
Old   August 7, 2018, 15:23
Default Computing the flux at an arbitrary 2D surface
Andy
andy_pr is on a distinguished road
I am trying to compute the massflow rate through an arbitrary surface (not necessarily a cell face). I had a look at this post:
Write cells and data intersecting a plane cuttingPlane
And tried to apply it to my case, which resulted in this:
1) Isolate the surface where I want to compute the mass flow
2) Reconstruct the flux at the surface using the surfaceScalarField values
3) Add the fluxes up
4) Print the result to the terminal
I've checked the area from (1) and printing is ok (4), so I guess my problem could be in the reconstruction (2) or the addition (3), but I'm not sure.
If this is true, essentially my question boils down to "how to reconstruct fluxes at an arbitrary surface and add them up?"
So, this is the code I think is wrong (I have to add up the flux from phases 1 and 2) - it's also in solver.C
// 1. Isolate the surface where I want to compute the mass flow
point pnt1(-0.007, 0.05, 0.0);
point pnt2(0.007, 0.05, 0.01);
point pnt3(0.007, 0.05, 0.0);
plane pl1(pnt1, pnt2, pnt3);
const keyType nameHere = keyType("orifice-cells");
sampledPlane smpPl("smpPl",mesh,pl1,nameHere, true);
smpPl.update();
// 2. In time loop: Reconstruct the flux at the surface
while(runTime.run())
volScalarField phi_reconstruct1 = fvc::reconstructMag(phi1);
scalarField slicedDesiredField1 = smpPl.sample(phi_reconstruct1);
volScalarField phi_reconstruct2 = fvc::reconstructMag(phi2);
scalarField slicedDesiredField2 = smpPl.sample(phi_reconstruct2);
scalar area_phantom = gSum(smpPl.magSf());
// 3. Add the fluxes up
scalar sumField_phantom_phi1 = 0;
scalar sumField_phantom_phi2 = 0;
if (area_phantom > 0)
    sumField_phantom_phi1 = gSum(slicedDesiredField1);
    sumField_phantom_phi2 = gSum(slicedDesiredField2);
// 4. Print the result to the terminal
Info<< "Area (m^2) = "
<< area_phantom
<< " \n" << endl;
Info << " Massflow (g/s) = "
<< abs(1000*2900*sumField_phantom_phi1 + 1000*1.3*sumField_phantom_phi2)
<< " \n" << endl;
I'm comparing the reconstructed massflows with the standard topoSet approach, where I sum the values at a faceZone using the dictionaries.
However, the result from the reconstructed phi is 18,536,101 g/s at t=6s, (reconstruct3.png) whilst the (correct) approach using topoSetDict gives 97.87 g/s (topoSet3.png), however the trends are similar.
Does anyone know where I've gone wrong?
Kind regards,
andypr
andy_pr is offline   Reply With Quote
arbitrary 2d clip, flux, phi, reconstruction
How to specify surface flux of a species? ked FLUENT 18 February 15, 2022 16:03
[ICEM] Problems with coedge curves and surfaces tommymoose ANSYS Meshing & Geometry 6 December 1, 2020 12:12
Total heat transf. rate vs Total surface heat flux Renato Sousa FLUENT 1 April 14, 2020 04:27
monitoring dynamic heat flux through a surface abdnakhi FLUENT 0 August 15, 2005 10:57
Radiation flux to the wall surface Jason Phoenics 1 May 26, 2004 02:13
