dimensionedScalar not updating, stuck on initial values
Old   August 5, 2018, 21:50
Default dimensionedScalar not updating, stuck on initial values
Anonymous
backscatter is on a distinguished road
Modifying pimpleFoam, I've created a dimensionedScalar which which computes the area weighted average over the boundary patches 'INLET' and 'OUTLET'. In createFields.H, I add the following entries to create the dimensionedScalar 'meanTOut' and 'meanTIn' (which are avg. temperatures on outlet and inlet patch respectively):
dimensionedScalar meanTOut     // used in TEqn.H
    "meanTOut",
    dimensionSet(0, 0, 0, 1, 0, 0 ,0),
    1 // initilization
dimensionedScalar meanTIn     // used in TEqn.H
    "meanTIn",
    0 // initilization
Then in TEqn.H, I add the following loop to compute the area weighted mean temperatures on these patches during every iteration:
// Area-weighted Temperature on OUTLET patch
    if (areaOut > 0)
    dimensionedScalar meanTOut = gSum
    mesh.magSf().boundaryField()[OUTLET]
    * T.boundaryField()[OUTLET]
    )/ areaOut;
// Area-weighted Temperature on INLET patch
    if (areaIn > 0)
    dimensionedScalar meanTIn = gSum
    mesh.magSf().boundaryField()[INLET]
    * T.boundaryField()[INLET]
    )/ areaIn;
     Info<< "Area weighted OUTLET patch temperature = " << meanTOut << nl << endl;
     Info<< "Area weighted INLET patch temperature = = " << meanTIn << nl << endl;
But when I run the solver on channel flow case, it doesn't update the 'meanTOut' and 'meanTIn' as per the loops given above. Instead, 'meanTOut' and 'meanTIn' are stuck at their initial values of "1" and "0" as initialized in createFields.H.
Am I missing anything basic here?
Anyhelp is appreciated.
PS: The other variables like areaIn, areaOut & patch labels like INLET and OUTLET etc. have been calculated elsewhere not shown in the code above.
backscatter is offline   Reply With Quote
Old   August 7, 2018, 09:18
Tom Fahner
tomf will become famous soon enoughtomf will become famous soon enough
Send a message via MSN to tomf Send a message via Skype™ to tomf
You may need to modify the code for some reason, but if you need to find the average of a field on a patch, there is already a functionObject:
surfaceFieldValue.
Depending on the version you use it may be called differently.
Regards,
Tom
tomf is offline   Reply With Quote
Old   August 7, 2018, 21:30
shinji nakagawa
snak is on a distinguished road
Hi,halo
Why do you define the "meanTout" twice?
If you define meanTout as dimensionedScalar in createFields.H,
there will be no need for defining it again in if{}.
Probably you are creating two different "meanTout" instances with a same name in the different scopes.
The values of meanTout inside if{} will be calculated. But, what you write out is not that one.
snak is offline   Reply With Quote
Segmentation fault when using reactingFOAM for Fluids Tommy Floessner OpenFOAM Running, Solving & CFD 4 April 22, 2018 13:30
HeatSource BC to the whole region in chtMultiRegionHeater xsa OpenFOAM Running, Solving & CFD 3 November 7, 2016 06:07
simpleFoam error - "Floating point exception" mbcx4jc2 OpenFOAM Running, Solving & CFD 12 August 4, 2015 03:20
Wrong fluctuation of pressure in transient simulation caitao OpenFOAM Running, Solving & CFD 2 March 5, 2015 22:33
Compressor Simulation using rhoPimpleDyMFoam Jetfire OpenFOAM Running, Solving & CFD 107 December 9, 2014 14:38
