Porting meshBalancing to OF2.1.1
Old   July 13, 2018, 14:55
Default Porting meshBalancing to OF2.1.1
Pete
strakey is on a distinguished road
Hi All - I am trying to port a dynamic load balancing routine (https://github.com/tgvoskuilen/meshBalancing) that was written for OF2.3.x to OF 2.1.1. The file dynamic RefineBalancedFvMeshTemplates.C file throws a compilation error as such: error: no mathcing function for call to Foam::HashTable<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>. This refers to the line "HashTable<GeoField*> flds(this....." around the 9th line below
The code is as follows:
#include "GeometricField.H"
#include "volMesh.H"
#include "fvPatchField.H"
template<class Type>
void Foam::dynamicRefineBalancedFvMesh::correctBoundaries()
    typedef GeometricField<Type, fvPatchField, volMesh> GeoField;
    HashTable<GeoField*> flds(this->objectRegistry::lookupClass<GeoField>());
    forAllIter(typename HashTable<GeoField*>, flds, iter)
        GeoField& fld = *iter();
        //mimic "evaluate" but only for coupled patches (processor or cyclic)
        // and only for blocking or nonBlocking comms (no scheduled comms)
        if
            Pstream::defaultCommsType == Pstream::blocking
         || Pstream::defaultCommsType == Pstream::nonBlocking
            label nReq = Pstream::nRequests();
            forAll(fld.boundaryField(), patchi)
                if(fld.boundaryField()[patchi].coupled())
                    fld.boundaryField()[patchi].initEvaluate
            // Block for any outstanding requests
            if
                Pstream::parRun()
             && Pstream::defaultCommsType == Pstream::nonBlocking
                Pstream::waitRequests(nReq);
                    fld.boundaryField()[patchi].evaluate
        else
            //Scheduled patch updates not supported
            FatalErrorIn
                "dynamicRefineBalancedFvMeshTemplates::correctBoundaries"
            )   << "Unsuported communications type "
                << Pstream::commsTypeNames[Pstream::defaultCommsType]
                << exit(FatalError);
Anyone have any idea why this would compile just fine in 2.3 and not in 2.1.1?
Thanks much!
Pete
strakey is offline   Reply With Quote
load balancing, meshbalancing
can not complie fluentDataToFoam in OF2.1.1 hewei OpenFOAM Pre-Processing 20 September 8, 2018 10:19
TwoPhaseEulerFoam high particle diameter problem OF2.1.1 mwaqas OpenFOAM Running, Solving & CFD 0 May 24, 2015 09:45
[Other] How to define internal walls for injector inside a combustion chamber by OF2.1.1 with sandy13 OpenFOAM Meshing & Mesh Conversion 0 May 22, 2013 07:59
Porting FoamX to cygwin using the latest version of MICO 7islands OpenFOAM Pre-Processing 17 December 31, 2008 02:27
Porting from T3E to SP2 Dr. Saud Khashan Main CFD Forum 0 May 23, 2000 16:43
