Reading in Custom Field for Multiple Blocks using blockMesh
Old   July 2, 2018, 21:02
Default Reading in Custom Field for Multiple Blocks using blockMesh
AustinG is on a distinguished road
I'm new here and I've looked through several forums and google searches with no luck on this issue, but feel free to redirect me if I have overlooked something. I am trying to read in a custom volScalarField, "R", using blockMesh. Should be pretty straight forward but I have a few blocks and I want a different value of "R" in one of the blocks. See the code snippets below.
blockMeshDict:
blocks
    hex ( . . . ) Region_0 ( . . . ) simpleGrading ( . . . )
    hex ( . . . ) Region_1 ( . . . ) simpleGrading ( . . . )
    hex ( . . . ) Region_5 ( . . . ) simpleGrading ( . . . )
R:
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    object      R;
dimensions      [0 1 -2 0 0 0 0];
internalField
    Region_0
        type            fixedValue;
        value           0;
    Region_1
        type            fixedValue;
        value           0;
    Region_5
        type            fixedValue;
        value           10E10;
createFields.H:
Info <<"Reading field R\n" <<endl;
volScalarField R
    IOobject
       IOobject::groupName("R",continuousPhaseName),
       runTime.timeName(),
       mesh,
       IOobject::MUST_READ,
       IOobject::AUTO_WRITE
    mesh
When I run blockMesh I get no error, but when I try to run my solver I get the following message:
Reading field R
--> FOAM FATAL IO ERROR:
Attempt to return dictionary entry as a primitive
file: . . . /0/R.internalField from line 23 to line 54.
    From function virtual Foam::ITstream& Foam::dictionaryEntry::stream() const
    in file db/dictionary/dictionaryEntry/dictionaryEntry.C at line 83.
FOAM aborting
Any help is appreciated!
AustinG is offline   Reply With Quote
Old   July 3, 2018, 11:28
clapointe is on a distinguished road
If you're only trying to set the values of R in one of your regions, why not try the setFields utility? The utility allows you to set the values of a field within a subsection of cells -- selected with boxToCell, for example. Here is a link to an example from one of the tutorials : https://github.com/OpenFOAM/OpenFOAM.../setFieldsDict.
Caelan
clapointe is offline   Reply With Quote
Old   July 5, 2018, 19:10
Hi Caelan,
That seems to do the trick for this case! Thanks for the help
Austin
blockmeshdict, createfields.h, volscalarfield
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 06:38
[Other] dynamicTopoFVMesh and pointDisplacement RandomUser OpenFOAM Meshing & Mesh Conversion 6 April 26, 2018 08:30
[Commercial meshers] Problem converting fluent mesh vinz OpenFOAM Meshing & Mesh Conversion 28 October 12, 2015 07:37
AMI memory leak? MichiB OpenFOAM Programming & Development 14 August 1, 2015 19:18
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 07:51
