Having trouble developing/compiling OpenFOAM on Mac
Old   June 27, 2018, 13:44
Default Having trouble developing/compiling OpenFOAM on Mac
Sgs
S
Sgs is on a distinguished road
I have OpenFOAM installed on a Mac and can use the software just fine (e.g. the cavity tutorial and my own setup scripts run fine) but I'm having trouble developing the code.
I run into a couple permissions errors while trying to run Allwmake from /opt/OpenFOAM/OpenFOAM-v1712, though I do have permissions to execute Allwmake. The error output is attached.
I don't have permissions to edit files in /opt/src and cannot seem to use chmod to change this.
I can log in to Docker as root with
docker run -u 0 -it mycontainerID bash
rather than with
./startMacOpenFOAM
and then I can edit files in the src directory with vi, but cannot run Allwmake because of the error
./Allwmake
Error (Allwmake) : not located in $WM_PROJECT_DIR
Check your OpenFOAM environment and installation
and
$ echo $WM_PROJECT_DIR
shows that this variable is not defined.
Also, after I detach from the container and then re-attach, my edit to a file in src vanished.
Any advice would be greatly appreciated.
Sgs is offline   Reply With Quote
Old   July 16, 2018, 16:50
Hasan Celik
PositronCascade is on a distinguished road
Why don't you directly compile the source code on Mac instead of considering Docker? I think it should work.
PositronCascade is offline   Reply With Quote
Old   July 29, 2018, 14:44
Default error using wmake on Docker for Mac
Sgs
S
Using Docker seems to be the recommended way to run OpenFOAM according to
https://www.openfoam.com/download/in...binary-mac.php
And the site suggests that there is
A complete development environment to compile local modifications and create executables.
and also that
The Docker environment contains a full OpenFOAM development environment so all Allwmake, wmake, wclean etc. commands work (it is running the actual environment OpenFOAM was compiled in!)
so it would be great to understand why wmake isn't working.
Old   August 7, 2018, 18:06
Default one solution
Sgs
S
https://cfd.direct/openfoam/user-gui...-applications/
allwmake, development environment, mac, openfoam, src
OpenFOAM v3.0+ ?? SBusch OpenFOAM 22 December 26, 2016 15:24
[OpenFOAM.org] Mac OS X 10.11 and OpenFOAM 3.0: Error when running ParaFoam with "command not found" hua OpenFOAM Installation 9 February 11, 2016 00:45
OpenFOAM Training: Programming CFD Course 12-13 and 19-20 April 2016 cfd.direct OpenFOAM Announcements from Other Sources 0 January 14, 2016 11:19
Trouble with sampleDict syntax for OpenFOAM 2.3.1 rawdoggity OpenFOAM Post-Processing 1 February 1, 2015 06:24
OpenFOAM 1.7 installation on Mac pepe.aero OpenFOAM Installation 0 April 16, 2011 13:32
