Oscillating cylinderTocell Field with topSetDict in openFoam
Old   June 21, 2018, 03:50
Default Oscillating cylinderTocell Field with topSetDict in openFoam
Ben 017
Ben UWIHANGANYE is on a distinguished road
Hello Foamers,
I want to ask if there is a way i can code a cylinderTocell field to oscillate.
Indeed, I created cylinderTocell field using topoSetDict, I want to know it can be put in motion.
I have seen in interFoam tutorials, setFieldsDict is used to give a velocity to a boxtocell Field.
Please help me to find out if there is a way this cylinderTocell Field can be moved(oscillating motion).
my ultimate goal is to simulate flow over that cylinder? (stationary and oscillating).
I thought that cylinder will be immersed not body fitted? Does it sound feasible?
I will be happy to hear from you.
Regards!
Ben UWIHANGANYE is offline   Reply With Quote
Old   June 24, 2018, 18:27
Michael Alletto
mAlletto will become famous soon enough
I think if you convect the field F by solving
fvm::ddt(F)
+ fvm::div(phi, F) = 0
it should work.
In principle you should solve a 3D advection equation. The mass flow
phi = fvc::interpolate(U) & mesh.Sf();
U has to be modified each time step to the desired value.
mAlletto is offline   Reply With Quote
Old   June 25, 2018, 02:19
Ben 017
fvm::ddt(F)
it should work.
Thank you for reply,
Help me as a beginner of Open Foam, How to model and code such oscillating motion of the Cylinder Field. Which solver to modify and which tutorial should I consult to understand this.
I have attached on this post my case setup that have lead me to that cylindrical shape.
Hope you are going to help
Thank you!
Foam::error::PrintStack almir OpenFOAM Running, Solving & CFD 92 May 21, 2024 08:56
[Other] dynamicTopoFVMesh and pointDisplacement RandomUser OpenFOAM Meshing & Mesh Conversion 6 April 26, 2018 08:30
Floating issue when running openfoam through grasshopper Mark JIN OpenFOAM 1 May 24, 2017 22:04
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 07:20
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 07:51
