Overset mesh for Fluid Structure Interaction in OpenFOAM
Old   June 20, 2018, 20:27
Default Overset mesh for Fluid Structure Interaction in OpenFOAM
Thaw Tar's Avatar
Thaw Tar
Thaw Tar is on a distinguished road
Hello everybody.
I want to use overset mesh for fluid structure interaction like those in the third figure of the attached picture below.
I think Official OF1706 or OF1712 do not have fluid structure interaction facilities like fsiFoam available for foam-extend 3.2 or 4.0. Thus, I think it is better to use overset mesh with foam-extend.
I asked Prof. Hrvoje Jasak for overset code in Foam-Extend. He kindly provided me with Foam-Extend 4.1 code (It is not officially released yet. But you can email to Prof. Jasak if you want to try).
But as far as I understand, this code focuses on solid body motion rather than deformed patches. For me, I need to deform the overset mesh while the background mesh is not changed. In other words, the whole overset domain (I am not sure I should use the word 'domain') should deform properly so that I can maintain mesh quality.
I guess I need to write a mesh motion solver for overset mesh region.
Any help will be greatly appreciated.
File Type: jpg 56368ff1-daf8-48a7-ad4c-e839c0924f95.jpg (77.8 KB, 169 views)
Thaw Tar is offline   Reply With Quote
Old   July 21, 2020, 12:53
Michael@UW is on a distinguished road
Hello Thaw,
Did you figure out how to deform the overset body?
In addtion, do you know how to deform the background mesh with overset? I try to use overset mesh in a deforming background mesh.
I noticed dynamicOversetFvMesh is derived from dynamicMotionSolverFvMesh which means overset should be able to coupled with dynamic motion solver like velocity/dispalcementLaplacian. But I do not know how to set up the dynamicMeshDict. Do I need write code to integrate overset with deforming?
Thank you!
Michael
Michael@UW is offline   Reply With Quote
Old   February 19, 2022, 02:54
TWB
quarkz is on a distinguished road
Anyone manage to get it working - overset mesh with deformation?
I wonder if it is possible, or the source code must be modified to make it work this way.
quarkz is offline   Reply With Quote
Old   February 19, 2022, 21:53
TWB
Just saw this post in the forum:
Overset mesh with deformable front mesh
Wonder if it can work.
Old   August 25, 2023, 18:56
Manchester
Tianyz is on a distinguished road
Originally Posted by Thaw Tar View Post
Hello everybody.
Hi Thaw,
How are you doing?
I have the same problem with using flexible overset mesh on OpenFOAM, have you managed to solve this problem?
Best,
Tian
Tianyz is offline   Reply With Quote
fsi, overset mesh
Map of the OpenFOAM Forum - Understanding where to post your questions! wyldckat OpenFOAM 10 September 2, 2021 06:29
Star CCM Overset Mesh Error (Rotating Turbine) thezack Siemens 7 October 12, 2016 12:14
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 10:38
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 04:52
Heat transfer and fluid structure interaction at OpenFOAM Workshop Milan 2008 ztukovic OpenFOAM 0 March 28, 2008 12:17
