Interface jumping conditions at interThermalPhaseChangeFoam |
June 8, 2018, 07:18 |
Peter Maroul
Rep Power: 8 |
Hello Foamers.
I have a question that has occupied my mind for some time as follows: As my thesis, I am obliged to solve laminar film condensation between parallel plates by VOF method. Does anyone know if interThermalPhaseChangeFoam framework (a VOF solver) assess interface jumping velocity & pressure conditions due to phase change as , for example, it has been considered in Welch paper (A Volume of Fluid Based Method for Fluid Flows with Phase Change)? Thanks a lot for any kind consult & answer. Peter Maroul Last edited by Pmaroul; June 11, 2018 at 08:21. |
March 29, 2022, 02:41 |
hari charan
Rep Power: 5 |
Hi peter,
Did you find the answer ? |
interthermalphasechange, phase change, vof |
Radiation in semi-transparent media with surface-to-surface model? | mpeppels | CFX | 11 | August 22, 2019 07:30 |
Interface boundary conditions Pointwise | Gio86 | Pointwise & Gridgen | 2 | June 10, 2017 07:14 |
Velocity vector in impeller passage | ngoc_tran_bao | CFX | 24 | May 3, 2016 21:16 |
Setting rotating frame of referece. | RPFigueiredo | CFX | 3 | October 28, 2014 04:59 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 06:28 |
