How a scalar FIeld can be moved at constant velocity
Old   June 8, 2018, 01:49
Default How a scalar FIeld can be moved at constant velocity
Upuli
upuli is on a distinguished road
Hi
I want to move a scalar which has value 1 to be moved along x axis at a constant speed. It has no diffusion or source terms. When I use +fvm::div term to calculate the movement due to velocity it gives fractions to the results. Can some one help me on how to do it?
regards
Upuli
upuli is offline   Reply With Quote
Old   June 13, 2018, 04:14
Upuli
Hi
I write the conservation equation for scalar solid as below.
fvScalarMatrix solidEqn
            fvm::ddt(solid)
       fvc::div(phigrate,solid)
    solve(solidEqn==Sc);
When I execute the solver the value of the solid is shown with the decimals (something like 1.24 etc) due to the divergence term. But when the scalar solid is moved at a constant velocity I want to have 1 or 0 as the value of the solid . Can someone please help me to fix the issue.
Thanks
Old   June 13, 2018, 12:38
Martin
msaravia is on a distinguished road
I think that probably you have numerical diffusion, check the discretization scheme for the convection term. Also, the convection term should be evaluated implicitly. See scalarTransporFoam solver.
msaravia is offline   Reply With Quote
Old   June 13, 2018, 18:29
Tobi's Avatar
Tobias Holzmann
Tobi has a spectacular aura aboutTobi has a spectacular aura aboutTobi has a spectacular aura about
Send a message via ICQ to Tobi Send a message via Skype™ to Tobi
Can you explain us, why you do not solve the scalar as:
solidEqn.solve();
What is 'Sc' ? In addition to the previous reply. What are your schemes and your solution tactic? Is everything converged? If you use 'Upwind' you should be between 0-1. All other schemes can lead to non-physical results. See my website and the numerical schemes topic.
Good luck.
Keep foaming,
Tobias Holzmann
Tobi is offline   Reply With Quote
Old   June 14, 2018, 05:56
Upuli
Thank you very much for the reply
Sc is a zero valued scalar .Actually I forgot that it can be written as
solidEqn.solve();
When the Gauss upwind scheme is used the the solid does not seem to move. This transport equation was added to a my own solver. It gives printstack error after about 30 seconds and stops.
Thanks
Old   June 14, 2018, 06:04
Tobi's Avatar
Tobias Holzmann
Without any information, you will not get any support. It is like: My cooked meal is not good, so tell my why?
If the scalar is not moving with Upwind it is an indication that something went wrong in your development. In addition, relaxing the scalar or matrix can help.
Good luck.
Keep foaming,
Tobias Holzmann
Old   June 18, 2018, 03:27
Upuli
Hi
sorry for inadequate data. Now I removed all the other conservation equations from the solver and only the solid conservation equation is present in the solver. It is the icoFoam solver. The solid movement appears only when
+fvc::div(phigrate,solid)
term is used. Fv scheme used is Upwind. The solver specifications are as below
    solid
        solver          smoothSolver;
        smoother        symGaussSeidel;
        tolerance       1e-05;
        relTol          0;
the boundaries for velocity ugrate is 0.001 m/s in the positive x direction for all the patches.
Now the solver is running and it is able to produce 1 and 0 only.
When
+fvm::div(phigrate,solid)
term is used the solids does not move(for any of the fvschemes).
Old   June 22, 2018, 06:23
Default use of mysetFieldsDict
Ben 017
Ben UWIHANGANYE is on a distinguished road
Hello Foamers,
I would like to ask how the modified setFieldsDict is used in FSI simulation.
Indeed, I want to simulate flow over a cylinder(stationary and oscillating). I have used toposetDict to map that cylinder in fluid Cartesian domain.
Let: eta=1 solid region, eta=0 fluid region.
Then i have a c++ code that gives me a value of eta each time step. The eta's value alternate from 0 to 1 and from 1 to 0. C++ code prints eta values in .dat format.
I am asking if it is possible to use setFieldsDict to move (oscillating motion) that cylinder as eta changes.
What should be my code looking like? can advise how i can rotate that solid region with that eta alternation?
I will be happy to hear from you!
Regard!
Ben UWIHANGANYE is offline   Reply With Quote
Old   June 22, 2018, 13:53
Upuli
Hi
What I used is setFields not the toposet Fields. I think both of them are similar. I modeled the translation movement. So the velocity component in x direction only. With the conditions given in previous post , my solver works correctly and it only gives 0 and 1. I think with correct representation of oscillating velocity (momentum) the movement of cylinder can be done.
I think rotation movement can be done if you know the angular velocity and taking the tangential velocity components in x and y directions.
regards
Upuli
Old   June 22, 2018, 14:11
Ben 017
Originally Posted by upuli View Post
Hi
regards
Upuli
Thank you for your reply,
I have attached a c++ program on this post. It is for undermped free vibration. the solid is modeled to vibrate freely. Can you help to know it can work in openFoam to rotate that cylinder.
May you share the code you used(benclaude2011@gmail.com) in your case.
Thank you!
Old   June 26, 2018, 01:51
Upuli
HI
I modified the icoFoam solver.below is what I have used
#include "fvCFD.H"
#include "pisoControl.H"
int main(int argc, char *argv[])
    #include "setRootCase.H"
    #include "createTime.H"
    #include "createMesh.H"
    pisoControl piso(mesh);
    #include "createFields.H"
    #include "initContinuityErrs.H"
    Info<< "\nStarting time loop\n" << endl;
    while (runTime.loop())
        Info<< "Time = " << runTime.timeName() << nl << endl;
        #include "CourantNo.H"
        // Momentum predictor
            fvm::ddt(solid)
solidEqn.solve();
        fvVectorMatrix UEqn
            fvm::ddt(U)
          + fvm::div(phi, U)
          - fvm::laplacian(nu, U)
        if (piso.momentumPredictor())
            solve(UEqn == -fvc::grad(p));
        // --- PISO loop
        while (piso.correct())
            volScalarField rAU(1.0/UEqn.A());
            volVectorField HbyA(constrainHbyA(rAU*UEqn.H(), U, p));
            surfaceScalarField phiHbyA
                "phiHbyA",
                fvc::flux(HbyA)
              + fvc::interpolate(rAU)*fvc::ddtCorr(U, phi)
            adjustPhi(phiHbyA, U, p);
            // Update the pressure BCs to ensure flux consistency
            constrainPressure(p, U, phiHbyA, rAU);
            // Non-orthogonal pressure corrector loop
            while (piso.correctNonOrthogonal())
                // Pressure corrector
                fvScalarMatrix pEqn
                    fvm::laplacian(rAU, p) == fvc::div(phiHbyA)
                pEqn.setReference(pRefCell, pRefValue);
                pEqn.solve(mesh.solver(p.select(piso.finalInnerIter())));
                if (piso.finalNonOrthogonalIter())
                    phi = phiHbyA - pEqn.flux();
            #include "continuityErrs.H"
            U = HbyA - rAU*fvc::grad(p);
            U.correctBoundaryConditions();
        runTime.write();
        Info<< "ExecutionTime = " << runTime.elapsedCpuTime() << " s"
            << "  ClockTime = " << runTime.elapsedClockTime() << " s"
            << nl << endl;
    Info<< "End\n" << endl;
    return 0;
The below code may help you. But it may not be a perfect way to do it.
fvScalarMatrix etaEqn
            fvm::ddt(eta)
       +fvc::div(phieta,eta)
etaEqn.solve();
I think you have to write conservation for the momentum change of eta
fvVectorMatrix UetaEqn
            fvm::ddt(Ueta)
          + fvm::div(pheta, Ueta)
 solve(UetaEqn ==−ω^2*x) ;
The above is only a suggestion. May not be a perfect method to solve your problem.
p { margin-bottom: 0.1in; direction: ltr; line-height: 120%; text-align: left; }a:link { }
Old   June 26, 2018, 03:12
Ben 017
Thank you,
I will try it and will let you know the progress.
I am asking:
no changes needed in creatField.H file? after compilation, what about in O folder fvscheme and fvsolution ?
what will be the impact of solve(UetaEqn ==−ω^2*x) in my case, will i be still in need of c++ program.
Regard!
Old   June 26, 2018, 04:04
Upuli
Hi
You have to declare the scalar field eta and vector field Ueta in creatField.H file.
regards
Old   June 26, 2018, 05:03
Ben 017
Dear Upuli,
I have tried to go as you advised but after compiling i have the following errors:
Making dependency list for source file myicoFoam.C
g++ -std=c++0x -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -O3 -DNoRepository -ftemplate-depth-100 -I/opt/openfoam4/src/finiteVolume/lnInclude -I/opt/openfoam4/src/meshTools/lnInclude -IlnInclude -I. -I/opt/openfoam4/src/OpenFOAM/lnInclude -I/opt/openfoam4/src/OSspecific/POSIX/lnInclude -fPIC -c myicoFoam.C -o Make/linux64GccDPInt32Opt/myicoFoam.o
myicoFoam.C:69:2: error: stray ‘\342’ in program
myicoFoam.C:69:2: error: stray ‘\210’ in program
myicoFoam.C:69:2: error: stray ‘\222’ in program
myicoFoam.C:69:2: error: stray ‘\317’ in program
myicoFoam.C:69:2: error: stray ‘\211’ in program
myicoFoam.C: In function ‘int main(int, char**)’:
myicoFoam.C:66:22: error: ‘phieta’ was not declared in this scope
+ fvm::div(phieta, Ueta)
myicoFoam.C:69:23: error: expected primary-expression before ‘^’ token
myicoFoam.C:69:26: error: ‘x’ was not declared in this scope
/opt/openfoam4/wmake/rules/General/transform:8: recipe for target 'Make/linux64GccDPInt32Opt/myicoFoam.o' failed
make: *** [Make/linux64GccDPInt32Opt/myicoFoam.o] Error 1
The following are the change made in myicoFoam.C:
#include "fvCFD.H"
fvm::ddt(Ueta)
fvm::ddt(eta)
etaEqn.solve();
fvVectorMatrix UEqn
fvm::ddt(U)
+ fvm::div(phi, U)
// --- PISO loop
"phiHbyA",
fvc::flux(HbyA)
fvScalarMatrix pEqn
pEqn.solve(mesh.solver(p.select(piso.finalInnerIte r())));
runTime.write();
<< nl << endl;
return 0;
my creatField.H:
Info<< "Reading transportProperties\n" << endl;
IOdictionary transportProperties
IOobject
"transportProperties",
runTime.constant(),
mesh,
IOobject::MUST_READ_IF_MODIFIED,
IOobject::NO_WRITE
dimensionedScalar nu
"nu",
dimViscosity,
transportProperties.lookup("nu")
Info<< "Reading field p\n" << endl;
volScalarField p
IOobject
"p",
runTime.timeName(),
mesh,
IOobject::MUST_READ,
IOobject::AUTO_WRITE
mesh
Info<< "Reading field U\n" << endl;
volVectorField U
IOobject
"U",
runTime.timeName(),
mesh,
mesh
Info<< "Reading field eta\n" << endl;
volScalarField eta
IOobject
"eta",
runTime.timeName(),
mesh,
mesh
Info<< "Reading field Ueta\n" << endl;
volVectorField Ueta
IOobject
"Ueta",
runTime.timeName(),
mesh,
mesh
#include "createPhi.H"
label pRefCell = 0;
scalar pRefValue = 0.0;
setRefCell(p, mesh.solutionDict().subDict("PISO"), pRefCell, pRefValue);
mesh.setFluxRequired(p.name());
May you help to know what is wrong, and if you can, you may let me know how your 0 folder was looking like to move that solid scalarField.
Thank you!
Old   June 26, 2018, 05:30
Upuli
Hi
You have to declare phieta and x , since these fields are created by you ,you have to declare them. They are not originally included in OpenFOAM. When you declare x ,also you have to take the displacement vector. And sorry for the wrong representation of mathematical operators. In OpenFOAM (^operator doesnot work) Please refer the programmers guide.
It should be
            fvm::ddt(Ueta)
 solve(UetaEqn ==−pow(ω,2)*x) ;
Old   June 26, 2018, 06:33
Ben 017
The remaining errors are:
solve(UetaEqn ==−ω*ω*x);
myicoFoam.C:69:27: error: ‘x’ was not declared in this scope
I am asking if all errors related to the displacement vector x which is not yet declared.
Can you help to know how I can declare it.
Regard!
Old   June 26, 2018, 13:18
Upuli
Hi
You have to declare it in create fields file. Since x is the displacement in either x,y or z directions you have to refer on how to write displacement in OpenFoam with reference to a certain direction.
Good luck
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 06:38
Constant velocity field Per OpenFOAM Running, Solving & CFD 13 March 8, 2018 08:27
Division by zero exception - loop over scalarField Pat84 OpenFOAM Programming & Development 6 February 18, 2017 06:57
Issue symmetryPlane 2.5d extruded airfoil simulation 281419 OpenFOAM Running, Solving & CFD 5 November 28, 2015 14:09
''unknown radialModelType type Gidaspow'' PROBLEM WITH THE BED TUTORIAL AndoniBM OpenFOAM Running, Solving & CFD 2 March 25, 2015 19:44
