Data stored after first fvm::laplacian/div
Old   June 7, 2018, 14:20
Default Data stored after first fvm::laplacian/div
Ville
rellumeister is on a distinguished road
Currently, I am investigating the possibility of optimizing a code. More prescisely, looking at the way OpenFOAM handles differential operators.
I took a tutorial case and clocked the time it took the solver to run over some differential operators at each timestep. I clocked fvm::laplacian(U) at the start of each timestep with the velocity field getting updated between timesteps. First, the fvm::laplacian(U) runs in roughly 110 tics, after which it drops down to a fifth (~20 tics) for the subsequent timesteps. After this, I added a fvm::div(phi,U) in the very beginning of the solver, right after the initialization of fields. By running the code again the tics were ~45 (divergence), ~85 (first laplacian) and ~20 (subsequent laplacians).
Something is clearly stored after the first differential operators which accounts for a shorter run time (data regarding the matrix?) However, by tracing the files, particularly fvmLaplacian, gaussLaplacianScheme and fmvDiv. However, I cannot understand what is going on...
So, essentially my question is what data is stored for future use when these are used the first time?
Br.
Ville
rellumeister is offline   Reply With Quote
fvm::div, fvm::laplacian, stored data
paraview - cell data or point data on plot over line bye bye my blue OpenFOAM 0 December 13, 2016 07:07
【Help】"Error: Update_Time_Level: invalid data" Chen FLUENT 2 August 24, 2014 08:51
[General] Warping Cells by Vectors? ronwelty ParaView 10 April 29, 2014 06:52
Problem in running ICEM grid in Openfoam Tarak OpenFOAM 6 September 9, 2011 18:51
CGNS vs Tecplot Data Format LWhitson2 Main CFD Forum 3 July 1, 2011 14:50
