Particle-interface interaction in interFOAM
Old   June 2, 2018, 02:34
Cool Particle-interface interaction in interFOAM
linhan.ge is on a distinguished road
Dear FOAMers,
I have a system where a bubble is modeled by the VOF (interFOAM) and particles are modeled by DEM. Now I need to add a force between the particle and the bubble which is a function of the distance between the particle and the interface (alpha = 0.5, I assume). I can easily access to the position of particles. Could anyone enlighten me how can I find the position of the interface at a code level?
Thank you all,
Linhan
linhan.ge is offline   Reply With Quote
Old   June 14, 2018, 05:05
Zanh
zangthanh is on a distinguished road
Hi Linhan,
I face to the same problem as your case, did you figure out it?
Thank you very much
zangthanh is offline   Reply With Quote
Old   June 14, 2018, 06:00
Default I haven't found a solution yet.
Originally Posted by zangthanh View Post
Hi Linhan,
Thank you very much
Hi zangthanh,
I am still looking for an appropriate method. So glad someone else is doing the similar work. Are you simulating the bubble-particle interaction using VOF-DEM method as well?
Old   June 14, 2018, 06:06
Zanh
Hi Linhan,
Yes, I will study it in the near future but I am now study the capillary rise with dynamic contact angle. So, I am trying to figure out the velocity at the interface to calculate the capillary number. But unfortunately, I am stilling working on it, I will update here if I find out it.
I hope some experts will help us to broaden us
force, interface, interfoam, particles
Multiphase flow - incorrect velocity on inlet Mike_Tom CFX 6 September 29, 2016 02:27
Basic Nozzle-Expander Design karmavatar CFX 20 March 20, 2016 09:44
interFOAM/ sclsVOF. Interface representation. Saideep OpenFOAM Running, Solving & CFD 0 January 28, 2016 12:22
Waterwheel shaped turbine inside a pipe simulation problem mshahed91 CFX 3 January 10, 2015 12:19
Particle tracking - Domain interface / FrozenRotor mohanrao CFX 4 January 23, 2008 04:39
