Setting change from k omega to k omega SST
Old   May 22, 2018, 06:15
Default Setting change from k omega to k omega SST
bingjr
bingo641 is on a distinguished road
Dear Openfoam users,
I am doing the simulation of a diffuser with simplefoam and turbulence model. I have tried several times both by k omega and k omega SST, but no result makes sense.
In terms of the k omega model, the inlet velocity profile is wrong. In terms of the k omega SST model, I have got many different weird results (most of them has irregular vortex or singularity with larger velocity).
Here are my settings for simulation.
k: fixedvalue (a small value like 1*10^-12)
omega: omegaWallFunction
nut: calculated 0 (I also tried nutUSpaldingWallFunction)
boundary: top : wall
bottom: wall
inlet: patch
outlet: patch
frontAndBack: empty
fvschemes:
ddtSchemes
default steadyState;
gradSchemes
default Gauss linear;
divSchemes
default none;
div(phi,U) bounded Gauss linearUpwind grad(U);
div(phi,k) bounded Gauss linearUpwind grad(k); (also tried //limitedLinear 1;//linearUpwind grad(k)
[/U]
[/I][/I] div(phi,omega) bounded Gauss linearUpwind grad(omega); // limitedLinear 1;//linearUpwind grad(omega);
div((nuEff*dev2(T(grad(U))))) Gauss linear;
laplacianSchemes
default Gauss linear corrected;
interpolationSchemes
default linear;
snGradSchemes
default corrected;
wallDist
method meshWave;
Could you please tell me what I should change? Thanks!
bingo641 is offline   Reply With Quote
Lift and Drag pattern change wit FLUENT 16 and 13 PISO for same mesh n solver setting arunraj FLUENT 0 June 2, 2016 23:58
lmtools - change to default setting niknasri STAR-CCM+ 6 November 11, 2011 15:20
k Omega SST SAS for OpenFOAM 1.5??? barath.ezhilan OpenFOAM Running, Solving & CFD 3 June 2, 2010 08:41
Wall function implementation K Omega SSt cbarry OpenFOAM 3 August 18, 2009 11:09
[OpenFOAM] Could not change parafoam setting parameter lin ParaView 0 February 17, 2008 05:06
