May 18, 2018, 10:30 |
problem in executing the new solver in loop
L S
Rep Power: 10 |
Hi everyone,
I have been trying to compile a new solver phaseChangeHeatFoam with dynamic meshing capabilities. Which I call as phaseChangeHeatDyMFoam. Now the problem is i have given end time as 20 sec and deltaT of 1e-5. still the code ends after solving for the first iteration. Its not running in loop. What can be the possible solution? HTML Code:
Create time Create mesh for time = 0 Selecting dynamicFvMesh dynamicRefineFvMesh Reading field p_rgh Reading field T Reading field alpha1 Reading field U Reading/calculating face flux field phi Creating phaseChangeTwoPhaseMixture Selecting phaseChange model Hardt Selecting incompressible transport model Newtonian Selecting incompressible transport model Newtonian Selecting turbulence model type laminar Reading g Reading hRef Calculating field g.h No finite volume options present Creating field kinetic energy K PIMPLE: Operating solver in PISO mode time step continuity errors : sum local = 0, global = 0, cumulative = 0 GAMGPCG: Solving for pcorr, Initial residual = 0, Final residual = 0, No Iterations 0 time step continuity errors : sum local = 0, global = 0, cumulative = 0 Courant Number mean: 0 max: 0 Starting time loop Interface Courant Number mean: 0 max: 0 Courant Number mean: 0 max: 0 deltaT = 1.11111e-05 Time = 1.1111111e-05 Selected 368 cells for refinement out of 4000. Refined from 4000 to 6576 cells. Selected 0 split points out of a possible 368. Execution time for mesh.update() = 0.03 s time step continuity errors : sum local = 0, global = 0, cumulative = 0 GAMGPCG: Solving for pcorr, Initial residual = 0, Final residual = 0, No Iterations 0 time step continuity errors : sum local = 0, global = 0, cumulative = 0 MULES: Solving for alpha1 Liquid phase volume fraction = 0.05 Min(alpha1) = 0 Max(alpha1) = 1 MULES: Solving for alpha1 Liquid phase volume fraction = 0.05 Min(alpha1) = 0 Max(alpha1) = 1 MULES: Solving for alpha1 Liquid phase volume fraction = 0.05 Min(alpha1) = 0 Max(alpha1) = 1 DILUPBiCG: Solving for Ux, Initial residual = 1, Final residual = 2.31942e-10, No Iterations 2 DILUPBiCG: Solving for Uy, Initial residual = 1, Final residual = 2.17407e-10, No Iterations 2 DILUPBiCG: Solving for Uz, Initial residual = 1, Final residual = 1.78713e-10, No Iterations 2 GAMG: Solving for p_rgh, Initial residual = 1, Final residual = 0.0126993, No Iterations 1 time step continuity errors : sum local = 0, global = 0, cumulative = 0 GAMG: Solving for p_rgh, Initial residual = 0.00653561, Final residual = 0.000103673, No Iterations 3 time step continuity errors : sum local = 0, global = 0, cumulative = 0 GAMGPCG: Solving for p_rgh, Initial residual = 0.00134984, Final residual = 9.37753e-09, No Iterations 5 time step continuity errors : sum local = 0, global = 0, cumulative = 0 solve TEqn DILUPBiCG: Solving for T, Initial residual = 1, Final residual = 1.05455e-13, No Iterations 2 TAve = 373.15 Min(T) = 363.15 Max(T) = 373.15 ExecutionTime = 0.15 s ClockTime = 0 s End |
May 23, 2018, 17:26 |
Tobias Holzmann
Rep Power: 52 |
as always. Please provide information! We cannot support you and that´s the reason why there is no reply to your problem. Good luck
Keep foaming, Tobias Holzmann |
[ANSYS Meshing] Help with element size | sandri_92 | ANSYS Meshing & Geometry | 14 | November 14, 2018 08:54 |
New solver not running in loop. | silviliril | OpenFOAM Running, Solving & CFD | 2 | May 21, 2018 09:55 |
Star cd es-ice solver error | ernarasimman | STAR-CD | 2 | September 12, 2014 01:01 |
Is there a problem in the Euler solver? | Combas | SU2 | 4 | March 28, 2014 16:48 |
patching problem unsteady solver | yellow-stuff | Main CFD Forum | 0 | September 25, 2009 02:26 |
