Guang
Rep Power: 11 ![]() |
Dear all,
I want to simulate the droplet behavior on a solid surface with interFoam (OpenFOAM-50). But I met a problem that in my case the wettability of the solid surface is not uniform, which means the contact angle is a function of the coordinate. CA=f(x,y). I found in OpenFoam there are already static and dynamic contact models. In the dynamic contact angle model, the contact is defined as a function of Uwall. I thought one way to solve this problem might be to change the CA function to make it coordinate dependent. As I am a beginner to OpenFOAM, I don't know how to call the local coordinate information of the wall in the Dynamic contact angle library. Does anyone have suggestions to me how to do it? Many thanks! Guang |
contact angle, droplet, openfoam |
whats the cause of error? | immortality | OpenFOAM Running, Solving & CFD | 13 | March 24, 2021 07:15 |
dynamic contact angle udf returns no value to solver | shiraz_man67 | Fluent UDF and Scheme Programming | 5 | July 3, 2018 14:51 |
[blockMesh] error message with modeling a cube with a hold at the center | hsingtzu | OpenFOAM Meshing & Mesh Conversion | 2 | March 14, 2012 09:56 |
[Netgen] Import netgen mesh to OpenFOAM | hsieh | OpenFOAM Meshing & Mesh Conversion | 32 | September 13, 2011 05:50 |
Problem with rhoSimpleFoam | matteo_gautero | OpenFOAM Running, Solving & CFD | 0 | February 28, 2008 06:51 |
