Solving the Same Governing Equations Over Different Regions |
April 25, 2018, 07:57 |
Saleh Abuhanieh
Rep Power: 8 |
Hi Foamers,
I am trying to develop a solver that can solve the following equations for different regions. I had to segregate the domain for different regions since a special BC shall be maintained between them. Equations from the standard solver are: solve ( fvm::laplacian(phi) + rho/epsilon ); rhoFlux = -k*mesh.magSf()*fvc::snGrad(phi); solve ( fvm::ddt(rho) + fvm::div(rhoFlux, rho) ); Noting that before going to the solving step, all the associated fields and constants in the equations are replaced by the regions related ones. I used ptrLists to define the same names for fields and constants for each region. The solver compiled without error, but when I run the case, it crashes once starts solving: #0 Foam::error:rintStack(Foam::Ostream&) at ??:? #1 Foam::sigSegv::sigHandler(int) at ??:? #2 ? in "/lib/x86_64-linux-gnu/libc.so.6" #3 Foam::UPtrList<Foam::fvsPatchField<double> >:perator[](int) const in "/home/sfa/OpenFOAM/sfa-5.0/platforms/linux64GccDPInt32Opt/bin/electrostaticMultiRegionFoam" #4 ? in "/home/sfa/OpenFOAM/sfa-5.0/platforms/linux64GccDPInt32Opt/bin/electrostaticMultiRegionFoam" #5 Foam::fvMatrix<double>::fvMatrix(Foam::GeometricFi eld<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::dimensionSet const&) at ??:? #6 Foam::fv::gaussLaplacianScheme<double, Foam::SymmTensor<double> >::fvmLaplacianUncorrected(Foam::GeometricField<do uble, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) at ??:? #7 Foam::fv::gaussLaplacianScheme<double, double>::fvmLaplacian(Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) at ??:? #8 Foam::tmp<Foam::fvMatrix<double> > Foam::fvm::laplacian<double>(Foam::GeometricField< double, Foam::fvPatchField, Foam::volMesh> const&) in "/home/sfa/OpenFOAM/sfa-5.0/platforms/linux64GccDPInt32Opt/bin/electrostaticMultiRegionFoam" #9 ? in "/home/sfa/OpenFOAM/sfa-5.0/platforms/linux64GccDPInt32Opt/bin/electrostaticMultiRegionFoam" #10 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #11 ? in "/home/sfa/OpenFOAM/sfa-5.0/platforms/linux64GccDPInt32Opt/bin/electrostaticMultiRegionFoam" Segmentation fault (core dumped) I thought maybe I need to define (explicitly) a fvMatrix for each region using ptrList also but i didn't know how since I've two equations, I tried one matrix for each equation just to see what will happen: phiMatrix ( fvm::laplacian(phi) + rho/epsilon ); phiMatrix.solve(); rhoFlux = -k*mesh.magSf()*fvc::snGrad(phi); rhoMatrix ( fvm::ddt(rho) + fvm::div(rhoFlux, rho) ); rhoMatrix.solve(); I received the the following compilation error: error: no match for call to ‘(Foam::fvScalarMatrix {aka Foam::fvMatrix<double>}) (Foam::tmp<Foam::fvMatrix<double> >)’ ); Any help will be appreciated Saleh |
April 26, 2018, 11:00 |
Saleh Abuhanieh
Rep Power: 8 |
any clue pls.
April 27, 2018, 06:03 |
Saleh Abuhanieh
Rep Power: 8 |
please notify me if the provided information is not sufficient
Problem with chtMultiregionFoam radiation boundary condition | baran_foam | OpenFOAM Running, Solving & CFD | 10 | December 17, 2019 18:36 |
Free surface issues with interDyMFoam for hydroturbine | oumnion | OpenFOAM Running, Solving & CFD | 0 | October 6, 2017 15:05 |
simpleFoam error - "Floating point exception" | mbcx4jc2 | OpenFOAM Running, Solving & CFD | 12 | August 4, 2015 03:20 |
Cannot run the code properly: very large time step continuity error | crst15 | OpenFOAM Running, Solving & CFD | 9 | December 14, 2014 19:17 |
Error while running rhoPisoFoam.. | nileshjrane | OpenFOAM Running, Solving & CFD | 8 | August 26, 2010 13:50 |
