April 20, 2018, 09:17 |
Different Pressure Equation Formulation!
Maximus Arelius
Rep Power: 9 |
Hi OF Community Members,
Greetings! I need your expertise with the following problem. I was going through Prof. Jasak's paper "Multi-dimensional simulation of thermal non-equilibrium channel flow!" where a different type of pressure equation was formulated as opposed to what is used in the variable density/compressible solvers of OpenFOAM. https://www.sciencedirect.com/scienc...0193220900192X In it the compressible/multiphase continuity is split from to Now considering compressible flow only . Hence material derivative is expanded as . It would be really helpful if you could share some thoughts on the following questions: 1.For a variable density flow with face flux as the Mass flux at face, the above equation will have volumetric flux phi, which is to be used to find mass flux by interpolation of density to the faces. Where should this in a (say) compressible solver be done( just after phi update or elsewhere)? 2.If we treat the pressure terms on the RHS i.e , temporal term and source term so as to impart numerical stability, then following phi = phi - pEqn.Flux() How will one update the volumetric fluxes as the pEqn now has a new convective term on the RHS following Dr.Jasak Thesis? 3.How is this kind of formulation different(physics wise) from that used in the regular openfoam solvers i.e. Note: The are used for a Favre averaged framework. Also the is treated as done in incompressible solvers in OF. Correct me if I am wrong anywhere! Thanks in advance
-- 🃏Maximus🃏 Last edited by godfatherBond; May 6, 2018 at 23:36. |
April 26, 2018, 05:52 |
#2 | |
Maximus Arelius
Rep Power: 9 |
-- 🃏Maximus🃏 Last edited by godfatherBond; April 30, 2018 at 00:07. |
June 13, 2018, 22:05 |
Maximus Arelius
Rep Power: 9 |
Hi FOAMers,
Still looking for an explanation. It would be beneficial if you could spare some time and have a look into it. Thanks
-- 🃏Maximus🃏 |
cfd - post, openfoam |
question regarding LES of pipe flow - pimpleFoam | Dan1788 | OpenFOAM Running, Solving & CFD | 37 | December 26, 2017 14:42 |
Pressure Outlet Guage pressure | Mohsin | FLUENT | 36 | April 29, 2016 17:16 |
The correction on pressure equation of SIMPLE algorithm in MRFSimpleFOAM solver | renyun0511 | OpenFOAM Running, Solving & CFD | 0 | November 10, 2010 01:47 |
How to add correcting pressure equation in SIMPLE of MRFSimpleFOAM? | renyun0511 | OpenFOAM Programming & Development | 0 | November 4, 2010 01:38 |
Pressure enigma. | Sara | Main CFD Forum | 22 | July 30, 2009 04:46 |
