Adding compiled turbulence model to the library - OpenFOAM 5.0 |
April 18, 2018, 11:53 |
David Cardoso Netto
Hi everyone!
I'm trying to implement a modified turbulence model in OpenFOAM 5.0 based on the following tutorial: http://www.tfd.chalmers.se/~hani/kur...ort_task_3.pdf I've followed the instructions for the first case of the tutorial and faced an error which was partially solved using the following: http://hassankassem.me/posts/newturbulencemodel/ After writing the makeTurModel.C file and trying to compile the turbulence model I get a redifinition error message as it follows: "opt/openfoam5/src/OpenFOAM/lnInclude/addToRunTimeSelectionTable.H:40:9: error: redefinition of 'Foam::RASModel<Foam::IncompressibleTurbulenceMode l<Foam::transportModel>" Does anyone know what may be going on? Any help would be very much appreciated. Best regards! |
Adding fvOptions to turbulence model | slottedLemon | OpenFOAM Programming & Development | 13 | May 28, 2020 13:27 |
OpenFOAM 5.0 Released | CFDFoundation | OpenFOAM Announcements from OpenFOAM Foundation | 11 | June 6, 2018 00:48 |
Adding a Turbulence Model | doug | OpenFOAM Running, Solving & CFD | 11 | May 21, 2018 14:54 |
Dummy turbulence model for OpenFoam 3 Simple FOAM | nusivares | OpenFOAM Running, Solving & CFD | 3 | March 10, 2016 23:28 |
Recompile turbulence model in OpenFoam | qtian | OpenFOAM Running, Solving & CFD | 7 | November 26, 2007 16:51 |
