Supporting multiple OF versions in library
Old   April 4, 2018, 06:53
Default Supporting multiple OF versions in library
Timofey Mukha
tiam is on a distinguished road
Dear all,
I am developing a library for wall-modelled LES in OpenFOAM
https://bitbucket.org/lesituu/libwallmodelledles
Unfortunately, the OF community is split and there are several forks, all with different APIs. Moreover, breaking API changes are continuously introduced within a single fork as well. I work with OpenFOAM 3.0.1 but I would like the code to support multiple versions of OF, to enlarge the user-base. I intended to have separate git branches corresponding to different versions. But I see already now that this is not going to work: propagating changes to several branches will take too long and it will be hard to keep them in sync. Therefore, I would like the code to determine the OF fork that is installed and have appropriate pieces of code compiled.
If I understand correctly, swak4foam manages to do that, using complicated makefiles and #ifdef macros in the code, like this, for example
#ifdef FOAM_NO_DIMENSIONEDINTERNAL_IN_GEOMETRIC
            << this->internalField().name()
#else
            << this->dimensionedInternalField().name()
#endif
I am wondering if there is any guide on how to do such things, swak4foam is a bit too huge to untangle everything.
Best,
Timofey
tiam is offline   Reply With Quote
version-specific code
[Other] Bashrc problem on multiple OpenFOAM versions Rolanzo OpenFOAM Installation 4 March 4, 2018 16:42
[OpenFOAM.org] Install openFOAM 3.0.1 in Ubuntu 16.04 LTS from Deb packs Pier84 OpenFOAM Installation 4 June 18, 2016 17:22
decomposePar is missing a library whk1992 OpenFOAM Pre-Processing 8 March 7, 2015 08:53
OpenFOAM static build on Cray XT5 asaijo OpenFOAM Installation 9 April 6, 2011 13:21
