Incorporate oscillating slip boundary condition |
February 23, 2018, 09:09 |
vishal
Rep Power: 13 |
Hi...
I am trying to simulate a wall boundary condition, in which the wall will move in an oscillating manner but the fluid will experience slip at the wall. Any help is really appreciating. Struggling with the problem for a long time. Thanks in advance. |
February 23, 2018, 09:28 |
Saurabh
Rep Power: 11 |
I am facing the same problem.
February 24, 2018, 06:13 |
Anurag
Rep Power: 12 |
Take a look at the movingCone case which uses the solver pimpleDymFoam. In fact, I made a blockMeshDict for the same case but modified the blocks so that it is now a moving solid block within a fluid. Since I have made it based on the movingCone case, you can just replace the existing blockMeshDict with the following and test it out (remember to change the boundary conditions from wedge to empty):
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 5 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // convertToMeters 0.001; vertices ( (-7.5 0 0) //0 (-7 0 0) //1 (-3.5 0 0) //2 (0 0 0) //3 (-7.5 1.75 0) //4 (-7 1.75 0) //5 (-3.5 2 0) //6 (0 2 0) //7 (-7.5 2.5 0) //8 (-7 2.5 0) //9 (-3.5 2.5 0) //10 (0 2.5 0) //11 (-7.5 1.75 1) //12 (-7 1.75 1) //13 (-3.5 2 1) //14 (0 2 1) //15 (-7.5 2.5 1) //16 (-7 2.5 1) //17 (-3.5 2.5 1) //18 (0 2.5 1) //19 (-7.5 0 1) //20 (-7 0 1) //21 (-3.5 0 1) //22 (0 0 1) //23 (-7 0.75 0) //24 (-7 0.75 1) //25 (-3.5 0.75 0) //26 (-3.5 0.75 1) //27 (-7.5 0.75 0) //28 (-7.5 0.75 1) //29 (0 0.75 0) //30 (0 0.75 1) //31 ); blocks ( hex (0 1 24 28 20 21 25 29) (15 20 1) simpleGrading (2 0.25 1) hex (28 24 5 4 29 25 13 12) (15 20 1) simpleGrading (2 0.25 1) hex (2 3 30 26 22 23 31 27) (20 20 1) simpleGrading (2 0.25 1) hex (26 30 7 6 27 31 15 14) (20 20 1) simpleGrading (2 0.25 1) hex (4 5 9 8 12 13 17 16) (15 20 1) simpleGrading (2 0.25 1) hex (5 6 10 9 13 14 18 17) (50 20 1) simpleGrading (2 0.25 1) hex (6 7 11 10 14 15 19 18) (20 20 1) simpleGrading (2 0.25 1) hex (1 2 26 24 21 22 27 25) (50 20 1) simpleGrading (2 0.25 1) ); edges ( ); boundary ( movingWall { type wall; faces ( (24 5 13 25) (5 6 14 13) (26 6 14 27) (24 26 27 25) ); } farFieldMoving { type patch; faces ( (9 17 18 10) (1 21 22 2) ); } fixedWall { type wall; faces ( (3 30 31 23) (30 7 15 31) (7 11 19 15) ); } axis { type empty; faces ( //(0 1 1 0) //(2 3 3 2) ); } left { type patch; faces ( (0 20 29 28) (28 29 12 4) (4 12 16 8) ); } farField { type patch; faces ( (8 16 17 9) (0 20 21 1) (10 18 19 11) (2 22 23 3) ); } back { type empty; faces ( (0 28 24 1) (28 4 5 24) (2 26 30 3) (26 6 7 30) (4 8 9 5) (5 9 10 6) (6 10 11 7) ); } front { type empty; faces ( (20 21 25 29) (29 25 13 12) (22 23 31 27) (27 31 15 14) (12 13 17 16) (13 14 18 17) (14 15 19 18) ); } ); mergePatchPairs ( ); // ************************************************************************* // |
February 26, 2018, 09:46 |
#4 | |
Saurabh
Rep Power: 11 |
Can you please suggest something. |
boundary condition, oscillating, slip |
Centrifugal fan | j0hnny | CFX | 13 | October 1, 2019 13:55 |
Problem in setting Boundary Condition | Madhatter92 | CFX | 12 | January 12, 2016 04:39 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 06:28 |
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 07:00 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 15:55 |
