February 22, 2018, 15:02 |
Understanding reaction rates
Chris L
Rep Power: 14 |
Hello all,
I'm trying to implement a new reaction rate type in OF 5.0. I am having some trouble understanding the code and if anyone can provide clarity it would be appreciated. In reactingFoam the species conversion is implemented in the YEqn.h file: Code:
fvScalarMatrix YiEqn ( fvm::ddt(rho, Yi) + mvConvection->fvmDiv(phi, Yi) - fvm::laplacian(turbulence->muEff(), Yi) == reaction->R(Yi) + fvOptions(rho, Yi) ); Code:
// Calculates the reaction rate // RR_[i] can then be called by chemistry.rr() in the YEqn.h file by the solver 644 template<class CompType, class ThermoType> 645 void Foam::chemistryModel<CompType, ThermoType>::calculate() 646 { 647 if (!this->chemistry_) 648 { 649 return; 650 } 651 // Gets the necessary property fields from thermo(). This is where all thermo properties are handled. 652 tmp<volScalarField> trho(this->thermo().rho()); 653 const scalarField& rho = trho(); 654 655 const scalarField& T = this->thermo().T(); 656 const scalarField& p = this->thermo().p(); 657 // Main loop for calculating the reaction rates // The index celli refeers to a specific cell in the mesh 658 forAll(rho, celli) 659 { 660 const scalar rhoi = rho[celli]; 661 const scalar Ti = T[celli]; 662 const scalar pi = p[celli]; 663 // The index i referrers to a species int 664 for (label i=0; i<nSpecie_; i++) 665 { 666 const scalar Yi = Y_[i][celli]; 667 c_[i] = rhoi*Yi/specieThermo_[i].W(); 668 } 669 // Omega modifies dcdt_, Ti and pi are copies and c_ isn't used in the following loop. 670 omega(c_, Ti, pi, dcdt_); 671 672 for (label i=0; i<nSpecie_; i++) 673 { 674 RR_[i][celli] = dcdt_[i]*specieThermo_[i].W(); 675 } 676 } 677 } So RR = dcdt*MolecularWeight dcdt is set by the omega function which is virtual Code:
template<class CompType, class ThermoType> 97 void Foam::chemistryModel<CompType, ThermoType>::omega 98 ( 99 const scalarField& c, 100 const scalar T, 101 const scalar p, 102 scalarField& dcdt 103 ) const 104 { 105 scalar pf, cf, pr, cr; 106 label lRef, rRef; 107 //initializes dcdt to 0 108 dcdt = Zero; 109 // For each rxn 110 forAll(reactions_, i) 111 { 112 const Reaction<ThermoType>& R = reactions_[i]; 113 114 scalar omegai = omega 115 ( 116 R, c, T, p, pf, cf, lRef, pr, cr, rRef 117 ); 118 119 forAll(R.lhs(), s) 120 { 121 const label si = R.lhs()[s].index; 122 const scalar sl = R.lhs()[s].stoichCoeff; // dcdt = stoichCoeff* 123 dcdt[si] -= sl*omegai; 124 } 125 126 forAll(R.rhs(), s) 127 { 128 const label si = R.rhs()[s].index; 129 const scalar sr = R.rhs()[s].stoichCoeff; 130 dcdt[si] += sr*omegai; 131 } 132 } 133 } template<class CompType, class ThermoType> 97 void Foam::chemistryModel<CompType, ThermoType>::omega 98 ( 99 const scalarField& c, 100 const scalar T, 101 const scalar p, 102 scalarField& dcdt 103 ) const 104 { 105 scalar pf, cf, pr, cr; 106 label lRef, rRef; 107 //initializes dcdt to 0 108 dcdt = Zero; 109 // For each rxn 110 forAll(reactions_, i) 111 { 112 const Reaction<ThermoType>& R = reactions_[i]; 113 114 scalar omegai = omega 115 ( 116 R, c, T, p, pf, cf, lRef, pr, cr, rRef 117 ); 118 119 forAll(R.lhs(), s) 120 { 121 const label si = R.lhs()[s].index; 122 const scalar sl = R.lhs()[s].stoichCoeff; // dcdt = stoichCoeff* 123 dcdt[si] -= sl*omegai; 124 } 125 126 forAll(R.rhs(), s) 127 { 128 const label si = R.rhs()[s].index; 129 const scalar sr = R.rhs()[s].stoichCoeff; 130 dcdt[si] += sr*omegai; 131 } 132 } 133 } Here dcdt = sigma(+-stoichCoeff*omegai) where the lhs/rhs of the reaction defines the sign of the stoichCoeff However I'm struggleing to understand the code for omegai Code:
157 template<class CompType, class ThermoType> 158 Foam::scalar Foam::chemistryModel<CompType, ThermoType>::omega 159 ( 160 const Reaction<ThermoType>& R, 161 const scalarField& c, 162 const scalar T, 163 const scalar p, 164 scalar& pf, 165 scalar& cf, 166 label& lRef, 167 scalar& pr, 168 scalar& cr, 169 label& rRef 170 ) const 171 { 172 const scalar kf = R.kf(p, T, c); 173 const scalar kr = R.kr(kf, p, T, c); 174 175 pf = 1.0; 176 pr = 1.0; 177 178 const label Nl = R.lhs().size(); 179 const label Nr = R.rhs().size(); 180 181 label slRef = 0; 182 lRef = R.lhs()[slRef].index; 183 184 pf = kf; 185 for (label s = 1; s < Nl; s++) 186 { 187 const label si = R.lhs()[s].index; 188 189 if (c[si] < c[lRef]) 190 { 191 const scalar exp = R.lhs()[slRef].exponent; 192 pf *= pow(max(0.0, c[lRef]), exp); 193 lRef = si; 194 slRef = s; 195 } 196 else 197 { 198 const scalar exp = R.lhs()[s].exponent; 199 pf *= pow(max(0.0, c[si]), exp); 200 } 201 } 202 cf = max(0.0, c[lRef]); 203 204 { 205 const scalar exp = R.lhs()[slRef].exponent; 206 if (exp < 1.0) 207 { 208 if (cf > SMALL) 209 { 210 pf *= pow(cf, exp - 1.0); 211 } 212 else 213 { 214 pf = 0.0; 215 } 216 } 217 else 218 { 219 pf *= pow(cf, exp - 1.0); 220 } 221 } 222 223 label srRef = 0; 224 rRef = R.rhs()[srRef].index; 225 226 // Find the matrix element and element position for the rhs 227 pr = kr; 228 for (label s = 1; s < Nr; s++) 229 { 230 const label si = R.rhs()[s].index; 231 if (c[si] < c[rRef]) 232 { 233 const scalar exp = R.rhs()[srRef].exponent; 234 pr *= pow(max(0.0, c[rRef]), exp); 235 rRef = si; 236 srRef = s; 237 } 238 else 239 { 240 const scalar exp = R.rhs()[s].exponent; 241 pr *= pow(max(0.0, c[si]), exp); 242 } 243 } 244 cr = max(0.0, c[rRef]); 245 246 { 247 const scalar exp = R.rhs()[srRef].exponent; 248 if (exp < 1.0) 249 { 250 if (cr>SMALL) 251 { 252 pr *= pow(cr, exp - 1.0); 253 } 254 else 255 { 256 pr = 0.0; 257 } 258 } 259 else 260 { 261 pr *= pow(cr, exp - 1.0); 262 } 263 } 264 265 return pf*cf - pr*cr; 266 } Also, I see that the Arrhenius reaction rate is calculated in ArrheniusReactionRateI.H but I dont see how this is implemented in omegai? Code:
inline Foam::scalar Foam::ArrheniusReactionRate::operator() ( const scalar p, const scalar T, const scalarField& ) const { scalar ak = A_; if (mag(beta_) > VSMALL) { ak *= pow(T, beta_); } if (mag(Ta_) > VSMALL) { ak *= exp(-Ta_/T); } return ak; } Thanks! |
February 26, 2018, 01:52 |
zhijie huo
I am having the same question. I suppose the code for omegai is to calculate the progress rate for one reaction as the expression below However, if that is the case, I cannot understand how the code achieve this calculation, especially for the snippet Code:
if (exp < 1.0) { if (cf > SMALL) { pf *= pow(cf, exp - 1.0); } else { pf = 0.0; } } else { pf *= pow(cf, exp - 1.0); } } From my understanding, the Arrhenius law is applied when kf and kr is calculated. |
Modelling species transport and implementing reaction rates | res | FLUENT | 0 | May 11, 2017 10:29 |
Segmentation fault in running alternateSteadyReactingFoam,why? | NewKid | OpenFOAM | 18 | January 20, 2011 16:55 |
combustion - reaction rates - urgent help needed | siri | Main CFD Forum | 2 | March 3, 2007 12:25 |
chemical reaction - decompostition | La S. Hyuck | CFX | 1 | May 23, 2001 00:07 |
Reaction rates | Szasz Robert | FLUENT | 1 | May 10, 2000 06:06 |
