Coupling Patches
Old   January 26, 2018, 10:07
Default Coupling Patches
StefanP is on a distinguished road
Dear FOAMers,
i want to couple the mass flow of an outlet BC to the inlet BC, thus I modified the pressureInletVelocity BC.
My problem is that the scalar outflow doesn't work and I can't use it.
The code looks as follows:
if (updated())
return;
const surfaceScalarField& rhoPhi =
db().lookupObject<surfaceScalarField>("rhoPhi");
const volScalarField& rho =
db().lookupObject<volScalarField>("rho");
tmp<vectorField> n = patch().nf();
const fvMesh& mesh = patch().boundaryMesh().mesh();
label couplingPatchID = mesh.boundaryMesh().findPatchID(couplingPatchName_ );
const Field<scalar>& magS = patch().magSf();
const fvPatchField<scalar>& rho_Patch = patch().lookupPatchField<volScalarField, scalar>(rhoName_);
if (rhoPhi.dimensions() == dimVelocity*dimArea*dimDensity)
const fvsPatchField<scalar>& outflow = sum(rhoPhi.boundaryField()[couplingPatchID]);
const scalar S_patch = sum(magS);
operator==(n*outflow/S_patch);
Info<< "mass flux = " <<outflow << endl <<endl;
else
FatalErrorInFunction
<< "dimensions of phi are not correct"
<< "\n on patch " << this->patch().name()
<< " of field " << this->internalField().name()
<< " in file " << this->internalField().objectPath()
<< exit(FatalError);
fixedValueFvPatchVectorField::updateCoeffs();
Can anyone help me with that problem?
THANK YOU IN ADVANCE
StefanP is offline   Reply With Quote
Old   January 27, 2018, 11:50
Nima Samkhaniani
nimasam is on a distinguished road
why don't you use cyclic boundary condition ?
My Personal Website (http://nimasamkhaniani.ir/)
Telegram channel (https://t.me/cfd_foam)
nimasam is offline   Reply With Quote
Old   January 29, 2018, 02:51
Thank you very much nimasam for your quick answer!
I think the way I wanted to tackle the problem was too complicated
Old   January 29, 2018, 07:03
But regardless of using cyclic boundary condition would be the better choice, what is the problem in my coded BC?
Old   January 29, 2018, 22:19
Yuncheng Xu (Cloud)
luther1990 is on a distinguished road
What is couplingPatchName_?
First, you need to make sure couplingPatchID is correct.
Second, in the following code, outflow is defined as fvsPatchField, which is not a scalar. Also, sum(rhoPhi.boundaryField() makes no sense.
I am not sure what version are you using, but in OF30x, it already implemented
    else if (phi.dimensions() == dimDensity*dimVelocity*dimArea)
        const fvPatchField<scalar>& rhop =
        operator==(n*phip/(rhop*magS));
Hope it can help you.
luther1990 is offline   Reply With Quote
boudary field, patch field
Foam::error::PrintStack almir OpenFOAM Running, Solving & CFD 92 May 21, 2024 08:56
Coupling patches in chtMultiRegionSimpleFoam Nkl OpenFOAM Running, Solving & CFD 17 May 19, 2023 10:23
Possible bug with stitchMesh and cyclics in OpenFoam Jack001 OpenFOAM Pre-Processing 0 May 21, 2016 09:00
[blockMesh] Merging edge patches Yosmcer OpenFOAM Meshing & Mesh Conversion 11 November 16, 2014 15:51
[swak4Foam] groovyBC for coupling of patches deniggo OpenFOAM Community Contributions 20 October 2, 2014 19:04
