How to equate a dimensional value to a scalar
Old   December 30, 2017, 01:01
Default How to equate a dimensional value to a scalar
Ram
ramsri95 is on a distinguished road
Hi All,
I'm trying to use PimpleFOAM to solve a channel flow. I wanted to obtain the pressure gradient used the maintain a constant mass flux. The pressure gradient in meanVelocityForce is a scalar, hence has dimensions of [0 0 0 0 0 0 0]. But I want to either convert it to a dimensionedScalar of [0 1 -2 0 0 0 0] or equate it to another dimensioned Scalar I've created with the above mentioned set.
I keep getting the error that
Different dimensions for =
dimensions : [0 1 -2 0 0 0 0] = [0 0 0 0 0 0 0]
Can someone please help!
Thanks!
Ram
ramsri95 is offline   Reply With Quote
Old   December 30, 2017, 16:02
shereez234's Avatar
M Sereez
shereez234 is on a distinguished road
Originally Posted by ramsri95 View Post
Hi All,
Thanks!
Ram
You can multiply it with a dimensionedScalar "one" of [ 0 1 -2 0 0 0 0]. But when there is different dimensions usually it means somewhere you have made a mistake in the derivation or something.
[ 0 1 -2 0 0 0 0 ] means the units is m/s2.
shereez234 is offline   Reply With Quote
Old   January 2, 2018, 03:08
Ram
Hey,
Thanks a lot! Apparently it turns out that the order of multiplication matters as mentioned in the file Scalar.H
Thanks a A lot!
adding dimensions, dimensionedscalar
problem during mpi in server: expected Scalar, found on line 0 the word 'nan' muth OpenFOAM Running, Solving & CFD 3 August 27, 2018 05:18
Division by zero exception - loop over scalarField Pat84 OpenFOAM Programming & Development 6 February 18, 2017 06:57
Issue symmetryPlane 2.5d extruded airfoil simulation 281419 OpenFOAM Running, Solving & CFD 5 November 28, 2015 14:09
Diverging solution in transonicMRFDyMFoam tsalter OpenFOAM Running, Solving & CFD 30 July 7, 2014 07:20
compressible flow in turbocharger riesotto OpenFOAM 50 May 26, 2014 02:47
