forces code
Old   December 22, 2017, 11:28
Default forces code
A. Min
alimea is on a distinguished road
Hi
I want to calculate forces for viscoelastic fluid flow. According to what I found out, just I should change the "fT" , i.e. tangential force. in forces.C code we can see:
-etaS*dev(twoSymm(fvc::grad(U)));
for shear stress.
I have three questions:
1- why did it use deviatoric form of twoSymm(fvc::grad(U)) tensor? As you know the shear stress tensor is calculated by:
-etaS*twoSymm(fvc::grad(U))
why deviatoric?!
2- why did it use minus in formula?
3- if I want to add it polymer stress tensor, what should I do? is it enough to write:
(+ or - ??)tau - etaS*dev(twoSymm(fvc::grad(U)));
thanks
alimea is offline   Reply With Quote
forces, openfoam, viscoelastic
Forces calculated by OpenFoam very strange tta223 OpenFOAM Post-Processing 3 August 5, 2017 10:10
The FOAM Documentation Project - SHUT-DOWN holger_marschall OpenFOAM 242 March 7, 2013 13:30
Reading forces within solver code SD@TUB OpenFOAM Running, Solving & CFD 0 February 28, 2010 19:39
Forces calulated through pressure LVDH OpenFOAM Post-Processing 2 February 26, 2010 04:15
public CFD Code development Heinz Wilkening Main CFD Forum 38 March 5, 1999 12:44
