No difference in solver behaviour with implicit source term
Old   December 9, 2017, 05:16
Default No difference in solver behaviour with implicit source term
Dan
Gesetzt is on a distinguished road
my old solver works like this:
 while (simple.correctNonOrthogonal())
            fvScalarMatrix TEqn
                        fvm::ddt(T)
                      + fvm::div(phi, T)
                      - fvm::laplacian(DM, T)
                      - T0/T1
                      +T/T1
                        fvOptions(T)
I wanted to treat the term T/T1 implicit, because T>0, and T1>0, so it would be negative on the RHS. As far as I have understand, this leads to better stability. Am I right?
So I changed my solver to this:
            fvScalarMatrix MzEqn
                        fvm::ddt(T)
                      + fvm::div(phi, T)
                      - T0/T1
                      + fvm::Sp(1/T1,T)
                        fvOptions(T)
But I can't see any difference in the results. T1 is a dimensionedScalar and T a volScalarField. How can I implement it in the right way?
Edit: I would like to add, that the problem is, that my scalar T should be bounded. I have a pipe and at the inlet I have a constant value of T=1, but my solver tends to go to 1.1 in the beginning of the pipe, which is not realistic. My thought was, that part of the problem is my source term.
I found out that when I us "bounded Gauss linearUpwind grad(T)" there is no problem. But I think it's no good idea to use the bounded scheme for transient solution?
Best Regards,
Gesetzt
Gesetzt is offline   Reply With Quote
Old   December 10, 2017, 07:14
Dan
I want to give information about my fvSchemes file also:
|  \\    /   O peration     | Version:  2.4.0                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      fvSchemes;
ddtSchemes
    default         Euler;
gradSchemes
    default         cellLimited Gauss linear 1;
divSchemes
    default         none;
    div(phi,T)       Gauss linearUpwind grad(T);
   //div(phi,T)       Gauss banana;
   //div(phi,T)      Gauss QUICK;
    //div(phi,T)      Gauss limitedLinear 0.5;
laplacianSchemes
    default         none;
    laplacian(DM,T) Gauss linear corrected;
    //laplacian(DM,T) Gauss linear limited 1;
interpolationSchemes
    default         linear;
snGradSchemes
    default        corrected;
fluxRequired
    default         no;
    T               ;
The main problem is, that my bounded scalar is going out of bounds. I thought the problem is maybe the solver, but actually I am not sure about this.
I tried different schemes, but the problem continues. Can anybody give me advice?
adding scalar source term in scalarTransportFoam solver fluidflowsteel OpenFOAM 1 July 25, 2016 22:58
[OpenFOAM.org] Error creating ParaView-4.1.0 OpenFOAM 2.3.0 tlcoons OpenFOAM Installation 13 April 20, 2016 18:34
what is swap4foam ?? AB08 OpenFOAM 28 February 2, 2016 02:22
[swak4Foam] swak4foam building problem GGerber OpenFOAM Community Contributions 54 April 24, 2015 17:02
[swak4Foam] build problem swak4Foam OF 2.2.0 mcathela OpenFOAM Community Contributions 14 April 23, 2013 14:59
