Omar Osama Mohamed
Rep Power: 11 ![]() |
Dear Foamers,
I am trying to understand the implementation of twoPhaseEulerFoam and I will be glad if someone may help. I wonder where the velocity for each field is calculated. I have read the PhD thesis by Rusche and in page 124, he says that equation 3.35 (UEqns.H) is solved but I can not find it in the code. could anyone please let me know where the velocity is calculated? I went through PEqn.H as well but it does not sound logical to calculate the velocity there, it sounds to be only correction to previously solved velocity field. Thanks to you |
multiphase flows, openfoam, twophaseeulerfoam |
whats the cause of error? | immortality | OpenFOAM Running, Solving & CFD | 13 | March 24, 2021 07:15 |
[snappyHexMesh] How to define to right point for locationInMesh | Mirage12 | OpenFOAM Meshing & Mesh Conversion | 7 | March 13, 2016 14:07 |
[blockMesh] error message with modeling a cube with a hold at the center | hsingtzu | OpenFOAM Meshing & Mesh Conversion | 2 | March 14, 2012 09:56 |
Euler equations? | Jan Ramboer | Main CFD Forum | 2 | August 19, 1999 01:58 |
