./Allwmake error and file duplication
Old   October 13, 2017, 11:39
Default ./Allwmake error and file duplication
Ali Noaman Ibrahim
alinuman15 is on a distinguished road
Dear All:-
After modifying one of the make subfiles and getting wmake error, I preferred to do ./Allmake. However, I got " make: Target 'application' not remade because of errors." And when I checked all the make files I found that all linux64Gcc* files had been duplicated. How can I resolve that problem?
My best
alinuman15 is offline   Reply With Quote
Old   December 31, 2017, 13:08
Retired Super Moderator
Bruno Santos
Quick answer: I guess that you've solved this issue by now, but we need more specific details on order to help you here.
My guess is that you were getting one folder that had "Gcc48" and another with just "Gcc" in the name "linux64Gcc*". This would explain why you were getting the error message.
If this was the case, then it was because you were not using the correct OpenFOAM shell environment settings. It would be necessary to know which installation instructions you followed in order to diagnose this problem.
Old   December 31, 2017, 17:16
Ali Noaman Ibrahim
[QUOTE=wyldckat;676525]Quick answer: I guess that you've solved this issue by now, but we need more specific details on order to help you here.
Thanks, Bruno, You are right! Due to the lake of knowledge at that time, I have solved it by deleting OF files and reinstalling it again! I kept the files for around one month hoping to get a reply but afterward, I compelled to delete my files. Hopefully, we will get prompt answer in 2018
