October 3, 2017, 06:56 |
Error: New Cannot Satisfy Memory Request
Thomas C. Sykes
Rep Power: 9 |
I'm editing the InterFoam solver to add an additional transport equation (for a passive scalar). To construct the compressive term (equiv. in alpha) in the scalar transport equation, I create a new normal (equiv. src/transportProperties/transportProperties.H). This is fine, except when I run the solver, I get the following error: Code:
new cannot satisfy memory request. This does not necessarily mean you have run out of virtual memory. It could be due to a stack violation caused by e.g. bad use of pointers or an out of date shared library Aborted (core dumped) Code:
// Overall normal for c surfaceVectorField nHatfv_forc(gradcf/( mag(gradcf) + ( 1e-8/pow(average(c.mesh().V()),1.0/3.0) ) )); // Cell surface vector const surfaceVectorField& Sf = mesh.Sf(); // nHat dot Sf const surfaceScalarField& nHat_forc = nHatfv_forc & Sf; // Standard face-flux compression coefficient surfaceScalarField Aphic(cCzbja.value()*mag(phi/mesh.magSf())); // Phi r (THIS LINE) surfaceScalarField Aphir(Aphic*nHat_forc); // 1 - c surfaceScalarField c2(1.0 - fvc::interpolate(c)); // Explicit flux of c surfaceScalarField phicc(fvc::interpolate(c)*( phi + c2*Aphir )); Any help appreciated. Thanks in advance |
October 4, 2017, 05:47 |
Found the Problem!
Thomas C. Sykes
Rep Power: 9 |
Ok, I found the obvious mistake I made! In case anyone else is struggling with a similar issue (now or in the future):
Clearly nHat_forc and (in general) Sf need to change during the simulation, so using const to define them as not modifiable is a bad idea! Replace Code:
const surfaceVectorField& Sf = mesh.Sf(); Code:
surfaceVectorField Sf = mesh.Sf(); My bad! |
June 5, 2018, 11:23 |
ERROR: new cannot satisfy memory request
#3 | |
A. Min
Rep Power: 12 |
Hi foamers
I have created a new viscosity model and compiled it successfully. But when I want to test it in a case it gives me this error: Quote:
Foam::PTTlinearTempDep::PTTlinearTempDep ( const word& name, const volVectorField& U, const surfaceScalarField& phi, const dictionary& dict ) : constitutiveEq(name, U, phi), tau_ ( IOobject ( "tau" + name, U.time().timeName(), U.mesh(), IOobject::MUST_READ, IOobject::AUTO_WRITE ), U.mesh() ), lambda_(dict.lookup("lambda")), etaP_T ( IOobject ( name, U.time().timeName(), U.db(), IOobject::NO_READ, IOobject::AUTO_WRITE ), calcEtaP_T() ) { checkForStab(dict); } Thanks |
new cannot satisfy memory request. | sahm | OpenFOAM Running, Solving & CFD | 18 | May 29, 2024 12:13 |
new cannot satisfy memory request openFoam!! what is the meaning of this? | adambarfi | OpenFOAM Running, Solving & CFD | 0 | November 2, 2013 14:57 |
Lenovo C30 memory configuration and discussions with Lenovo | matthewe | Hardware | 3 | October 17, 2013 11:23 |
[OpenFOAM] Saving ParaFoam views and case | sail | ParaView | 9 | November 25, 2011 16:46 |
IcoDyMFoam New cannot satisfy memory request | yuhai | OpenFOAM Running, Solving & CFD | 2 | December 10, 2008 06:15 |
