foam-extend 4.0 compile error, incorrect path in RASModel.H needs fixing |
September 1, 2017, 03:32 |
Klaus
Rep Power: 22 |
I get a compile error: /opt/foam/foam-extend-4.0/src/turbulenceModels/incompressible/RAS/RASModel/RASModel.H:44:60: fatal error: incompressible/turbulenceModel/turbulenceModel.H: Date oder Verzeichnis nicht gefunden (File or Folder/Directory not found) The path in RASModel.H is wrong, it's incompressible/turbulenceModel/turbulenceModel.H but it should be turbulenceModels/incompressible/turbulenceModel/turbulenceModel.H I changed it, tried the absolute path, tried to include it via the Make/options file but nothing works, I keep getting the very same error message. Any hints how to fix the problem? Klaus |
September 4, 2017, 03:23 |
Hrvoje Jasak
Rep Power: 33 |
What are you compiling? Have a look at eg simpleFoam to see how to set up paths
Hrvoje Jasak Providing commercial FOAM/OpenFOAM and CFD Consulting: http://wikki.co.uk |
September 4, 2017, 07:29 |
Klaus
Rep Power: 22 |
I am working on a turbulence model. As usual it's based on an existing one but from another OF version.
The problem I see is that RASModel.H includes the following line #include "turbulenceModels/incompressible/turbulenceModel/turbulenceModel.H" but the file is located at src/: incompressible/RAS/RASModel/turbulenceModel.H so there is a mismatch (turbulenceModels) and I am not able to fix it. |
Foam::error::PrintStack | almir | OpenFOAM Running, Solving & CFD | 92 | May 21, 2024 08:56 |
NO Moving Probes for Moving Mesh in Foam Extend 4.0 | alia | OpenFOAM Running, Solving & CFD | 6 | June 25, 2018 10:24 |
error with reactingFoam | BakedAlmonds | OpenFOAM Running, Solving & CFD | 4 | June 22, 2016 03:21 |
ParaView-4.0.1 did not compile for foam extend 3.0 installation | mhkenergy | OpenFOAM Installation | 8 | June 4, 2014 03:26 |
