Calculate the size of the cells
Old   August 29, 2017, 12:22
Default Calculate the size of the cells
West Midlands
sok99 is on a distinguished road
Hi foamers,
I am trying to write a script in openfoam that outputs the dimensions of each cell (x,y,z). Any ideas?
sok99 is offline   Reply With Quote
Old   September 11, 2017, 03:32
Huipeng Xiao
Huipeng Xiao is on a distinguished road
it is easy. you merely add your slove with some c++ code to caculate the size of cells. ( ˘•ω•˘ )
Sent from my Le X620 using CFD Online Forum mobile app
Huipeng Xiao is offline   Reply With Quote
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 09:54
[snappyHexMesh] Problem: after snappyHexMesh, the cells size are not the same kanes OpenFOAM Meshing & Mesh Conversion 0 January 25, 2016 09:06
[ICEM] Help with fixing imported IGES model siw ANSYS Meshing & Geometry 24 August 24, 2010 12:22
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 20:43
Problems in compiling paraview in Suse 10.3 platform chiven OpenFOAM Installation 3 December 1, 2009 08:21
