erro: no match for operator[]
Like Tree6Likes
Old   August 16, 2017, 17:59
Default erro: no match for operator[]
Vedamt Chittlangia
vcvedant is an unknown quantity at this point
I am modifying a turbulence model and for a part of the code I get an error:
error: no match for 'operator[]' in 'FST[cellI]'
for the function
tmp<volScalarField> myModel::rCm
     const volScalarField& tke
     tmp<volScalarField> rC = tke/tke;
     tmp<volScalarField> FST = tke;
     const fvPatchScalarField* topTKE(tke.boundaryField()[2]);
     forAll(tke, cellI)
          FST[cellI] = topTKE[3];
     return rC;
I get an additional
error: 'class Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> >' has no member named 'size'
when I tried
     forAll(FST,cellI)
What should I change for FST such that I can access individual value of FST for each cell in the mesh and assign it some value?
Thanks,
vcvedant is offline   Reply With Quote
Old   August 17, 2017, 12:42
Zeppo's Avatar
Sergei
Zeppo will become famous soon enough
FST()[cellI] = topTKE[3];
Zeppo is offline   Reply With Quote
Old   August 17, 2017, 13:49
Vu
DoQuocVu is on a distinguished road
Hi Vedamt,
As far as i know, the forAll(FST, cellI) means: for(int i=0; i< A; i++), with A is a integer which is the size of FST.
However, you defined FST as a volScalarField which is a 2D or 3D matrix according to your mesh, and size of a matrix is mxn but not a scalar so you cannot use it for the "for" loop.
The only solution I can come up with is using another scalarField:
scalarField& FSTin_ = FST.internalField();
forAll(FSTin_, cellI)
     FSTin_[cellI] = topTKE[3];
Good luck,
Vu
DoQuocVu is offline   Reply With Quote
Old   August 17, 2017, 16:13
Zeppo's Avatar
Sergei
scalarField& FSTin_ = FST().internalField();
Old   August 25, 2017, 21:41
Sugajen
Sugajen is on a distinguished road
Hi all,
I did a similar expression as below but got an error.
error:
error: invalid initialization of reference of type ‘Foam::scalarField& {aka Foam::Field<double>&}’ from expression of type ‘const Internal {aka const Foam::DimensionedField<double, Foam::volMesh>}’
     scalarField& varNuIn_ = varNu_().internalField();
code:
    Foam::tmp<Foam::volScalarField> varNu_;
Any ideas?
Sugajen is offline   Reply With Quote
Old   August 27, 2017, 12:23
Zeppo's Avatar
Sergei
Originally Posted by Sugajen View Post
If you are not going to modify the field later on:
const scalarField& varNuIn_ = varNu_();
otherwise:
scalarField& varNuIn_ = varNu_.ref();
Sugajen, vcvedant and sibo like this.
Old   October 10, 2017, 12:57
sibo
sibo is on a distinguished road
Hi Sergel,
I have a similar error message when compiling a customized solver in OF_4.1.
It is a dynamic solver and in order to assign my calculated displacement value "dispVals" to cellDisplacement boundary, I use this line:
PointDisplacement.boundaryField()[patchID] == dispVals;
and the error is:
error: no match for ‘operator==’ (operand types are ‘const Foam:ointPatchField<Foam::Vector<double> >’ and ‘Foam::vectorField {aka Foam::Field<Foam::Vector<double> >}’)
here I want to use this "==" to force assignment.
Do you know how to solve this problem? Any suggestion is welcome!
Thanks a lot!
sibo is offline   Reply With Quote
Old   October 14, 2017, 07:58
Zeppo's Avatar
Sergei
PointDisplacement.boundaryFieldRef()[patchID] == dispVals;
sibo likes this.
Old   October 14, 2017, 11:20
sibo
Thanks a lot! I solved this problem a few days ago, so I think in the new version they name the const and non-const function differently.
Old   January 19, 2018, 08:00
Nick
NICKTAVOUKT is on a distinguished road
Hi guys I also have a similar problem... more specifically:
When I try to compile the following:
inline tmp<volVectorField> solidParticleCloud::momentumSource() const
tmp<volVectorField> tsource
new volVectorField
IOobject
"smom",
mesh_.time().timeName(),
mesh_,
IOobject::NO_READ,
IOobject::NO_WRITE
mesh_,
dimensionedVector
"zero",
dimensionSet(1, -2, -2, 0, 0),
vector::zero
tsource().internalField() = smom_/mesh_.cellVolumes();
return tsource;
and I get the following error:
solidParticleCloudI.H:91:57: error: no match for 'operator=' (operand types are 'const Internal {aka const Foam:imensionedField<Foam::Vector<double>, Foam::volMesh>}' and 'Foam::tmp<Foam::Field<Foam::Vector<double> > >')
Interestingly enough when I compiled the same code in OF3 I did not have any problems... The problem occurs only when compiled n OF5
I would really appreciate any help!
Thanks!
NICKTAVOUKT is offline   Reply With Quote
Old   January 19, 2018, 09:43
sibo
HI Nick,
Try
tsource().internalFieldRef() = smom_/mesh_.cellVolumes();
I believe in the version 4.0 and after that, they seperate the const and non-const function with different names. InternalField() provides the const reference to the internal field, internalFieldRef() provides a non-const reference.
Old   January 19, 2018, 10:47
Nick
Thanks Sibo,
I'll give it a try and see what comes out of it!
Old   February 6, 2018, 10:55
Nick
Hi all,
I found this link which describes how to update older code versions to the newest... which also gives an answer to most of the questions posed in this thread. I hope you find it helpful!
https://www.openfoam.com/documentati...rade-guide.php
Regards,
Nick
Old   April 25, 2018, 09:28
JulianS is on a distinguished road
Hey everyone,
This thread already helped me a lot. Thanks for this guys!
Now I would like to do something quite similar, just the other way round as the issue solved before here:
Originally Posted by Zeppo View Post
When I try to write the PointDisplacement entries to a vectorField, like this:
dispVals=PointDisplacement.boundaryFieldRef()[patchID];
I get the error message:
error: no match for ‘operator=’ (operand types are ‘Foam::vectorField {aka Foam::Field<Foam::Vector<double> >}’ and ‘Foam::pointPatchField<Foam::Vector<double> >’)
Does anyone know what I'm doing wrong or how to solve this?
Thanks!
JulianS is offline   Reply With Quote
Old   March 30, 2020, 08:14
Default Problem in printing the values
  #15
sujata
sujata is on a distinguished road
hello everyone.
I am using multiphaseEulerfoam solver. I am new to OpenFOAM and using version 4.1 . I am trying to print u velocity, Reynolds No in the phasepair.C file
Foam::tmp<Foam::volScalarField> Foam:hasePair::magUr() const
return mag(phase1().U() - phase2().U());
Info<< "magUr =" <<magUr()[0] << endl;
Foam::tmp<Foam::volVectorField> Foam:hasePair::Ur() const
return dispersed().U() - continuous().U();
Foam::tmp<Foam::volScalarField> Foam:hasePair::Re() const
return magUr()*dispersed().d()/continuous().nu();
Info<< "Re =" <<Re()[0] << endl;
The error I am getting is as follows
phasePair/phasePair/phasePair.C(108): error: no operator "[]" matches these operands
operand types are: Foam::tmp<Foam::GeometricField<Foam::scalar, Foam::fvPatchField, Foam::volMesh>> [ int ]
phasePair/phasePair/phasePair.C(121): error: no operator "[]" matches these operands
I want to print it for 0th cell. Can anyone help me with this.
sujata is offline   Reply With Quote
Old   March 30, 2020, 09:09
Vu
Hi Sujata,
the function mag() return a scalar, thus magUr() is a scalar and it doesn't have [] operator
sujata likes this.
Old   March 30, 2020, 10:19
Zeppo's Avatar
Sergei
Originally Posted by sujata View Post
hello everyone.
    tmp<volScalarField> ret = mag(phase1().U() - phase2().U());
    Info<< "magUr =" << ret()[0] << endl;
    return ret;
Function mag here returns tmp<volScalarField>. You can access its first element through [0];
sujata likes this.
Old   March 30, 2020, 10:48
Zeppo's Avatar
Sergei
Thanks!
dispVals=PointDisplacement.boundaryField()[patchID].primitiveField();
This way you get a copy of internal patch field. When you modify any value of dispVals no changes will be made to PointDisplacement.boundaryField()[patchID]!
Old   March 30, 2022, 08:21
Feng
wind_ is on a distinguished road
Thanks!
Hi,Nick
I also have this problem in OF5x, and I changed
tsource().internalField() =...
tsource().primitiveField() =...
but it doesn't work, how to fix it?
Thanks
Feng
wind_ is offline   Reply With Quote
Old   March 30, 2022, 08:36
Feng
Originally Posted by wind_ View Post
Hi,Nick
Thanks
Feng
This thread is the detail.Error while compiling a solidParticle library based on interFoam in OF5x
cell value, operator, size, tmp<volscalarfield>
[ANSYS Meshing] Match Control, is this weird or am I stupid? Moufle ANSYS Meshing & Geometry 2 November 18, 2015 17:00
createPatch Segmentation Fault (CORE DUMPED) sam.ho OpenFOAM Pre-Processing 2 April 21, 2014 03:01
Match Control and Symmetry Boundary Condtions in a quasi 2D calculation peterputer ANSYS Meshing & Geometry 0 May 15, 2012 09:53
gmsh2ToFoam sarajags_89 OpenFOAM 0 November 24, 2009 23:50
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 05:15
