erro: no match for operator[]
Like Tree6Likes
Old   April 1, 2022, 05:49
Mark Olesen
olesen has a spectacular aura aboutolesen has a spectacular aura about
Originally Posted by wind_ View Post
Hi,Nick
I also have this problem in OF5x, and I changed
tsource().internalField() =...
tsource().primitiveField() =...
but it doesn't work, how to fix it?
Thanks
Feng
If you read the docs on GeometricField (https://www.openfoam.com/documentati...tricField.html) you will notice that both internalField() and primitiveField() return const refs to the field. Cannot really change those by placing them on the LHS of an assignment. The compiler is correct to complain. If you want modifiable references, then you should be using the ref() or primitiveFieldRef() methods.
olesen is offline   Reply With Quote
cell value, operator, size, tmp<volscalarfield>
[ANSYS Meshing] Match Control, is this weird or am I stupid? Moufle ANSYS Meshing & Geometry 2 November 18, 2015 17:00
createPatch Segmentation Fault (CORE DUMPED) sam.ho OpenFOAM Pre-Processing 2 April 21, 2014 03:01
Match Control and Symmetry Boundary Condtions in a quasi 2D calculation peterputer ANSYS Meshing & Geometry 0 May 15, 2012 09:53
gmsh2ToFoam sarajags_89 OpenFOAM 0 November 24, 2009 23:50
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 05:15
