Verifying Mass Flux at Outlet Boundary
Old   July 31, 2017, 19:34
Default Verifying Mass Flux at Outlet Boundary
victorious_BIG is on a distinguished road
I am verifying the calculation of several key quantities in openfoam.
Specifically, I want to make sure that I understood how "phi" is calculated at the boundary faces.
In the code below I expect phi = dot product of face normal vector with velocity * area (phi = A n_i U_i). I have verified this on inlet boundaries, but I am finding that at outlet boundaries phi ~= A n_i U_i. The numbers are very close, but not exact. Does anyone know why?
Thanks for the help!
const fvBoundaryMesh& boundaryMesh = mesh.boundary();
forAll(boundaryMesh, patchI)
const fvPatch& patch = boundaryMesh[patchI];
const fvsPatchField<scalar> &phiCheck =
patch.lookupPatchField<surfaceScalarField, scalar>("phi");
const fvPatchField<vector> &U2 =
patch.lookupPatchField<volVectorField, vector>("U");
forAll(patch, faceI)
vector faceNormal = patch.Sf()[faceI];
scalar phiOut = phiCheck[faceI];
vector vel2 = U2[faceI];
Info << "Face Area vector (A n_i): " << faceNormal << endl;
Info << "Velocity (v_i): " << vel2 << endl;
Info << "Phi: " << phiOut << endl;
Info << "Calculated Phi: A n_i & v_i: " << (faceNormal & vel2) << endl;
Info << endl;
victorious_BIG is offline   Reply With Quote
Old   August 1, 2017, 17:45
Update:
I am using the icoFoam solver. I find that if I comment out the "U.correctBoundaryConditions();" line at the bottom of the solver, then my code above does lead to exact agreement between phi and A n_i * U_i.
So, a new question, what exactly is "correctBoundaryConditions()" changing and why doesn't the change seem to propagate out to the patch field values?
mass flow, outlet
Wind turbine simulation Saturn CFX 60 July 17, 2024 06:45
Difficulty In Setting Boundary Conditions Moinul Haque CFX 4 November 25, 2014 18:30
Setting rotating frame of referece. RPFigueiredo CFX 3 October 28, 2014 05:59
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 05:05
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 16:55
