deltaN_ value in interfaceProperties used in interFoam solver
Old   July 26, 2017, 15:05
Default deltaN_ value in interfaceProperties used in interFoam solver
Saideep
Saideep is on a distinguished road
According to interFoam's: interfaceProperties.C file available in the source (src), I am wondering whats the theory behind "deltaN_" value?
Its defined as deltaN_ = \frac{1e-8}{V^{\frac{1}{3}}}
It should always be a minuscule value lower than \nabla \alpha and its purpose is to avoid a floating point error.
Why shouldn't it be directly 1e-8 (hard-coded) but includes a volume variable in the equation?
I went through H.Rusche's thesis but this specific term was not discussed there.
Any insights here?
Saideep
Saideep is offline   Reply With Quote
interface properties, interfoam
deltaT is getting very small on using interFoam solver dhineshcecfd OpenFOAM Running, Solving & CFD 10 September 4, 2022 03:33
2D flow around a circular cylinder case with interFoam solver shuoxue OpenFOAM Running, Solving & CFD 2 January 14, 2020 14:23
Hybrid discretisation - blend factor gcoopermax CFX 5 September 23, 2016 09:05
Cannot compile new solver (interFoam with Temperature) MdoNascimento OpenFOAM Programming & Development 2 June 29, 2015 15:31
Problem of InterFoam with LES SpalartAllmarasIDDES keepfit OpenFOAM 3 August 29, 2013 12:21
