Vedamt Chittlangia
Rep Power: 9 ![]() |
I am working on HPC clusters and don't have permission to install new solvers at $FOAM_APPBIN. When I tried to change Make/files EXE = $(FOAM_USER_APPBIN)/mySolver it gives an error that the directory does not exist. So, where and how do I define the user bin directory in my home folder? Thanks. |
Bobby
Rep Power: 15 ![]() |
Hey
You should have a folder named mySolver in the related directory. Most likely, you have mySolver.C file, however, the name of the folder is not mySolver. |
Rep Power: 10 ![]() |
What you are doing is correct, at least for a local computer.
Verify that you have this variable set and you can access this directory from the login node: Code:
ls $FOAM_USER_APPBIN I assume that you are compiling from the login node. If you maybe are trying to compile using another node, then make sure that the OpenFOAM environment is also loaded there. |
Vedamt Chittlangia
Hello MakisH,
Thanks for the response. But I have problem following how to source bashrc. I am not the root user of the system and OpenFOAM is installed in a different directory than my home directory. How and what should I change in the bashrc to add these commands? |
What happens if you run the following anywhere? If it displays the help message of blockMesh, then OpenFOAM's bashrc is loaded correctly. If you get an error, then it is not.
blockMesh -help Code:
source /opt/openfoam4/etc/bashrc You can add this command in your own ~/.bashrc file (which you should have the permission to read and edit), so that it will be executed every time you login. After you edit and save your own ~/.bashrc file, you need to open a new terminal or source it again, so that the environment is reloaded. |
Vedamt Chittlangia
Thank you for your help.
I installed OpenFOAM in my home directory and instead used the source command to load bashrc each time I would open terminal. |
Athanasios Niotis
Rep Power: 8 ![]() |
I had the same issue regarding HPC and the $FOAM_USER_APPBIN. For this reason, I compiled my new solver (mySolver) in one different directory lets say "/users/myName/OpenFOAM/myApps" then I created a new alias with the name of the solver which targets its location. alias mySolver="/users/myName/OpenFOAM/myApps/mySolver" Then if you go to the case typing nySolver and it runs.. hopefully.. BR Thanos |
Rep Power: 16 ![]() |
My two cents:
AFAIK, this alias is defined here: Code:
$FOAM_ETC/config/settings.sh |
bashrc, openfoam 2.2.2, solver error, user defined |
change the under-relaxation factors | hotboy | FLUENT | 4 | May 28, 2015 22:25 |
Mass Transfer without Phase Change in InterPhaseChangeFoam | Parisa_Khiabani | OpenFOAM Running, Solving & CFD | 5 | May 26, 2015 09:40 |
No density change - rhoSimplecFoam | krapic | OpenFOAM | 1 | November 29, 2014 18:39 |
Help with writing a macro/UDF_file/script to change BC at regular time step intervals | Codophobia | Fluent Multiphase | 0 | April 24, 2014 10:07 |
Old OpenFOAM Users, Read This if you Want to Change Username | pete | Site Help, Feedback & Discussions | 0 | March 16, 2009 04:29 |
